Old 10-11-2005, 03:53 PM   #1
Purs
Got Big Block?
Purs's Avatar
Messed up my door handle :whine:
Can someone describe how to fix my door handle button? I've got a '68 that the exterior button on my door is pushed in and won't come out. It's also flopping around in there. I've take the door panel off and found no pieces laying the the bottom of the door. I've got an assembly manual but can't find a page that has an exploded drawing of the mechanism. What should I be looking for to put back together? I've got access to a '71 parts truck that has a good door handle, is it the same as the '68? thanks!
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 10-11-2005, 04:52 PM   #2
Putter
More Cowbell....
Putter's Avatar
There is a small metal part (like a square plate...but small) that has a hole in it to guide the button in a straight line in and out, and it holds the pressure on the spring so the button pops back out at you. That tab will break off if the inside is rusted a little. Held in place by little bent metal tabs. Usually just easier to replace the handle. I see plenty of owners poking their fingers through the hole to open the door!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-11-2005, 04:55 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
They are the same. There should be a spring and a plate sitting in the bottom of your door though. Unless you take the time to drill and pin the plate back in place, fixing the old one will be a waste of time. It will brake again shortly therafter. The 71 will work. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-11-2005, 05:28 PM   #4
Purs
Got Big Block?
Purs's Avatar
thanks guys.
Old 10-11-2005, 06:21 PM   #5
matthufham
unless it just needs oil.
matthufham is offline   Reply With Quote
Old 10-11-2005, 10:34 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
I don't think it would be a waste of time to fix. It is real easy. The trick is to not try and bend it too much. I have probably repaired around 20 of these and not lost a single patient. If you have a replacement handle just change it out and practice on the old one. You have nothing to lose.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 10-12-2005, 10:06 AM   #7
Purs
Got Big Block?
Purs's Avatar
Thanks everyone. I got the handle off my parts truck, it was in great shape. Got it put on, works great. Tried to fix my old one, broke it in less than 30 seconds
Old 10-12-2005, 02:28 PM   #8
Premium72
Premium72's Avatar
yeah...i got new ones....real easy fix if its not rusted to pieces. good to see you got another.
Premium72 is offline   Reply With Quote
