TOTY 2006
![]() Join Date: Dec 1999
Power Steering pump Pulley....
Hi All,
On trying to remove a P/S pulley, I was able to remove one that is a two groove pully with a nut on the end of the shaft, but now I am trying to remove a single groove pulley where the pump does not have a nut, but the shaft is hollow and has threads. Using a two arm puller, I only end up pulling chunks of metal off of the center of the pulley. What is the correct way to do this? |
Jostrans68
napa has a puller for this its about 30.00 but it saves pulleys my advice is to put a hose clamp low on the jaws and tighted helps it not to move, I have pulled many of these when I worked in the parts stores and this worked the best. My .02 worth
![]() former 67-72 now with a 96 silverado |
