Old 10-12-2005, 06:30 PM   #1
wessscott
wessscott's Avatar
Shock Help
I am looking for a set of coilovers for the front of my truck. It has a 72 C10 swap with 3" Belltech drop spindles and 1" ECE springs. I have a pair of Doetsch shocks but want a set of coilovers if available. Any info appreciated.
70 step with 68 clip, still in the body shop. GMPP 385 fast burn crate motor, 4:11 eaton. 5 lug 4/6" drop
wessscott is offline   Reply With Quote
Old 10-12-2005, 06:35 PM   #2
tomatocity
tomatocity's Avatar
Were the Belltech 3" drop spindles a true 3" drop?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 10-12-2005, 08:01 PM   #3
wessscott
wessscott's Avatar
Sad to say they are, I had to go to 16" and now I have 17". It had to have 16" or better to clear the caliper.
Old 10-12-2005, 08:46 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you install front coil overs, you're going to want to build a much better front shock mount setup. These trucks are terrible about wallowing the frame out where the upper shock stud attaches. It will get worse with a coil over. The mounts are intended only for shocks, not to help give lift, or support to the truck like a coil over does.
