"Bondo, just say no!"
disc brake conversion question
It is to my understanding that for a drum to disc conversion on my 69 chev c10, I need spindles from a 73-87 is this correct? if so what other parts from the 73-87, booster, brake lines, etc... can i use?
"WORK NOW, SLEEP WHEN I'M DEAD, SPEND EVERY PENNY I MAKE" 69 C-10 SWB Stepside (ground up resto in progress) 86 Yugo 69 Honda pc50 moped see my work @ http://www.myspace.com/inkorperated free site for pics |
![]() Join Date: Mar 2003
Tie rod tapers are different, as the ball joints I believe. Center link. pittman. I'm sure other members will chime in. The swap on my 1 ton took quite a few parts.
Designated A-hole!
http://67-72chevytrucks.com/vboard/s...d.php3?t=13692
http://www.67-72chevytrucks.com/vboa...77#post1298277 Or you could do like I am about to do, which is swap the whole crossmember out from under a 73 and up truck.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
swapping the whole crossmember to a 73+, that works. does it bolt up right?
any cutting or welding involved. why dont more people do this instead of all the misc parts swap?
![]() Join Date: Jun 2003
If I ever get back to the frame under construction, I intend to do the 73 crosssmember change. I have a 73 available, this should allow me to stick with all 73 parts.
Re: disc brake conversion question
If anyone wants some stock spindles off an 86 2wd c-10, how's ($25+sh)
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
got myself a complete crossmember for my new frame today, what can i do for rear end? can i use the 87 with the five lug? what other options do I have to switch my rear to five lug?
