Old 10-13-2005, 12:56 AM   #1
Deuce
Deuce's Avatar
When building a "NEW" bed.............Where do you start????
I am building a "NEW" short fleetside bed using mostly aftermarket parts. I have all the pieces, just not to sure where to start??
Any ideas??
Thanks.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 10-13-2005, 12:59 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Steel or wood floor?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-13-2005, 01:42 AM   #3
Deuce
Deuce's Avatar
Chuck
Sorry. Wood floor.
Old 10-13-2005, 03:21 AM   #4
68_396Noel
so what you need to do is choose what wood you want to use and then stain and seal the pieces and depending if you are going to have this truck go off road or stay in the garage and in from the rain then you might rhino-line the underside. take a look at these decks they are really nice.
68_396Noel is offline   Reply With Quote
Old 10-13-2005, 06:03 AM   #5
.030over
Junior Member
.030over's Avatar
Also interested
I will be doing the same thing on my '67 SWB fleet with all new parts soon. If anyone has done this, with some pictures, i would like to see it go to the FAQ section. I guess there is nothing magical about it. Just nice to see how others have done it first!
Scott
'67 SWB big block project
'85 C60 school bus motorhome conversion
.030over is offline   Reply With Quote
Old 10-13-2005, 07:42 AM   #6
demi
demi's Avatar
This pic shows the prefitting of the boards to mark holes and check
overall placement with steel strips. This is probably the most important step.
Trial fit everything.
The bed was tore down, and in my case, I painted the steel strips.
Then I began sanding and finishing the wood after the holes were drilled.
hope this helps
demi is offline   Reply With Quote
Old 10-13-2005, 08:07 AM   #7
Joe67
67 is sold
Very nice install
You had to drill the holes yourself? I thought these came pre-cut, pre-drilled, etc?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-13-2005, 09:43 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
if you want to know the order of assembly I would say the order to go is
cross sills,wood floor, wheel wells, bed sides, front panel, tail gate. i think you would need a helper to align the bed sides & front panel.
I suggest doing a trial fit of everything before applying any finish. and take lots of pics during the "mock-up" to share & for future reference. (FAQ submission).
I would also do the whole thing on the truck frame so that it all lines up with the frame holes.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-13-2005, 11:01 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
^That's how my dad and I put my stepside bed back together.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-13-2005, 12:06 PM   #10
Deuce
Deuce's Avatar
Thanks alot!!
Old 10-13-2005, 12:56 PM   #11
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Bed Assembly
We have an installation instruction for converting to wood floor. http://www.mar-k.com/67-72conv.pdf It is useful for putting the bed back together whether or not you are converting to wood. As was mentioned, it is very important to trial fit everything before painting, especially if you are using a lot of new or aftermarket parts. We suggest doing the wood after the metal is fitted. There are many suppliers of bed wood, some of them drill the bed to frame mounting holes. Mar-K wood comes cut to length and width with proper grooves and cutouts for the wheels. Our wood may be ordered with or without bed-to-frame holes predrilled, and hidden bed to frame holes are available. I think you will have to locate and drill the bed side/wheel tub holes for wood from most suppliers. We have other installation information including wood finish tests. http://www.mar-k.com/installation_hints.html Good luck on your project.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 10-13-2005, 02:13 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
kool, I was hoping you would chime in with some professionla advice. thanks.
Old 10-13-2005, 02:25 PM   #13
legends
i am also getting ready to build a fleetside wood floor bed using all repro. parts. I hope to see progress pictures.
legends is offline   Reply With Quote
Old 10-13-2005, 02:26 PM   #14
4tiresngas
An American Soldier
4tiresngas's Avatar
I built my stepside from all reproduction parts. I started with the front panel and bedsides and the rear sill. Put everything together finger tight. Then make sure you measure corner to corner and ensure the bed is square before tightening everything down (don't ask me how I know). I had everything assembled and the wood was the last thing to go in. I did it with the help of my stepson and his friend. It really wasn't too hard. Good luck.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 10-13-2005, 03:23 PM   #15
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
kool, I was hoping you would chime in with some professional advice. thanks.
Glad to help. Feel free to pm or email us if we need to respond to a question. Unfortunately, we don't get to read all posts on a timely basis and may not see it in time. We do check messages frequently.
Mar-Ktech
GET MAR-K Quality!
Old 10-13-2005, 05:56 PM   #16
weasel29gm
SLOW BUT SURE,BUT CLOSER
Demi thats a nice lookin' box in your truck!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 10-14-2005, 12:26 AM   #17
Deuce
Deuce's Avatar
Mar-Ktech
Thank You for the info!!!
Old 10-16-2005, 06:27 PM   #18
Riles72
Re: When building a "NEW" bed.............Where do you start????
On my stepside, we did the front panel to the bedsides first, then the rear cross sill. After that, we mounted the cross sills, then finally the tailgate. The wood was the last thing to go in since it was highly highly highly finished and we were afraid it'd be scratched.
72 Chevy short stepside
350/350
tilt, vintage air a/c
sunset Orange Metallic paint
Early Classic 2.5/4 drop
eagle series 211 wheels
Riles72 is offline   Reply With Quote
