Old 10-13-2005, 11:29 AM   #1
76bonanza
76bonanza's Avatar
gas tank sending unit
First chevy duty has them for 29.95 is this the cheapest you guys have seen?
Second the one I have now has a rubber fuel line jumping sending unit to metal line about 2 inches the new ones look like they are to bolt to metal line?
Can I just cut off the fitting and use the rubber hose? Or is this not good? I dont really want to redo the hard fuel line.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-13-2005, 12:20 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Which fitting are you talking about cutting?. The sender should be connected to a steel line that goes thru a grommet in the floor.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-13-2005, 01:17 PM   #3
76bonanza
76bonanza's Avatar
My steel line has no fitting on it it has a rubber fuel line for about 2 inches. so it is like this steel line from floor 2 inchs of rubber fuel hose the steel line from sender no fittings at all.
1968 c10
lowered 3" 4"
