Old 10-13-2005, 09:08 PM   #1
phatcat
engine temp Question
I have a slightly built 400 small block and i'm wondering what the normal engine temp should be. Currently it is running in the 140-165 range on average. I live up in the mountians and the air temp's are cooler. I recently put on a 1'' carb spacer and now have a miss at lower rpm's. Could this be becouse the engine is not running hot enough? Also just instaled new plug wires so that is not it. Any advise would be great.. Thanks
phatcat is offline   Reply With Quote
Old 10-13-2005, 10:04 PM   #2
sinister72
sinister72's Avatar
you may have a small vacumn leak around your spacer,,,
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 10-13-2005, 10:23 PM   #3
jhow66
jhow66's Avatar
What temp thermostat are you running?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-13-2005, 10:38 PM   #4
phatcat
engine temp
Not sure on the thermostat, i'm guessing a 160 mabey. As far as the spacer goes I don't really think there is a leak, the motor has had the miss before the spacer was installed it was at a higher running temp and now it misses even when it's colder..
