Old 10-13-2005, 11:36 PM   #1
qksilver
Roller bearings for front hubs
I am trying to put a 58 panel on the road. Payed way to much for it, rusty but solid.
I haven't decided if it's worth doing completely. I want to make it road worthy, runs and steers well.
i want to update the wheel bearings and have seen the cost of the kits. Does anybody know the part numbers for the inner, outer bearings and grease seals
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 10-21-2005, 09:38 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Roller bearings for front hubs
Its not just the bearings that need changing. You need a spacer for the bearing offset and seal ring. If you don't mind waiting a few days I can pull apart the old setup I used prior to putting an IFS in mine I can get you the numbers.
dwcsr is offline   Reply With Quote
Old 10-21-2005, 11:40 AM   #3
qksilver
Thanks, no hurry at all
Steve
