Old 10-14-2005, 12:00 AM   #1
pound41
WTB: Need 4 washers/bolts for front inner fender
I need the 4 washers/brackets( for lack of a better term) and the bolts That go into the 4 bolt hole/ indented places on a front fender well. It looks like are sort of rounded and 1 is square. I need 2 complete sets. Thanks
pound41 is offline   Reply With Quote
Old 10-14-2005, 10:32 AM   #2
junkyardjohn
junkyardjohn's Avatar
NAPA WILL HAVE THEM. ASK FOR BODY BOLTS. I THINK THATS WHAT YOU ARE ASKING FOR?? JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-15-2005, 06:47 AM   #3
pound41
Junkyard John: I am fixing the floor pan/Pillar post on my 70 blazer. so when I removed the fender the only bolts holding the inner wheel well in was the small outside bolts.Rusted away at the front. The 4 big bolts were missing. I looked at my 71Blazer all 4 big bolts that bolt up through the middle area of the well Have an indented or scooped out area around the bolt hole since they are in the curved area of the well. My 71 has plates/washers that fit in the scooped out area and give the bolt a flat surface to tighten against. Those are what I am really looking for
Thanks Billy
Old 10-15-2005, 07:30 AM   #4
Tim Christian
Tim Christian's Avatar
I have a inner/outter fender bolt set with all the j-nuts for $20.00
Tim Christian is offline   Reply With Quote
Old 10-15-2005, 11:27 AM   #5
junkyardjohn
IT SEEMS TO ME THAT ALL THE INNER FENDER BOLTS ARE THE SAME DIA. WITH THE EXCEPTION OF THE BOLT THAT GOES THRU THE INNER TO THE CAB. SOUNDS LIKE TIM CHRISTIAN CAN FIX YOU RIGHT UP. JOHN
junkyardjohn
DON'T RENT U-HAUL
