72 Paint color codes?
I tried using the search but no luck, only gives one to two results that have nothing to do with the search criteria. Any help would be appreciated. The truck is blue and white.
Thanks alot. Wilson
Wilson 1972 Cheyenne LWB, 350ci TH-350. Restoration in progress. |
#2 | |
Thats the Hillbilly way
Try this ,http://autocolorlibrary.com/cgi-bin/search/search.pl
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Where did they come up with those names?Are they accurate,like what was used in sales brocures?`Cuz that ain`t what they`re called on the options list.
#4 | |
![]() ![]() Quote:
That would be a page from a dealer data book..thats the real GM list. Just like my 72 dealer data book has. Your acctually missing a little info to be totally accurate. They used different numbers for codes depending on whether you had the white in the middle, top, or just on top. It's another page next to this one actually. If your looking to do a glove box code with the proper number, contact me, I can help you out. I got the real book.
You can see where it says shown are conventional 2 tones consult interior exterior chart for other 2 tone combinations. |
Thanks alot. Any ideas on what color white to use on two-tone trucks? Mine is Hawaiian Blue and ? white. Thanks in advance for the help.
Wilson
# 521 is the white
I have that book...Bible.I know the # is what counts.You can`t get anyone to mix paint on a name anyway.
521 is called Frost White.
Dupont number was 817-L Rinshed - Mason number was A-1347 Ditzler number was 2185 There are 3 different option numbers depending on what your truck was ordered as for paint scheme. Those being either Deluxe, Conventional or Custom. If you have top as white only then your option number is 542 if your doing it back original to white on top and the rest hawaiian blue. The white you use is / are those brands and lot numbers I listed above. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
WOW, thanks guys. Thats alot of info. Mine is white top, then blue, white middle, then blue bottom. I really appreciate all the info. This will defenitley help on the painting process which I hope will be soon.
Wilson
Re: 72 Paint color codes?
Say, I must say this has been a big help to me too since I was confused about the code for green. The different code for two tone helps big time.
