Old 10-14-2005, 06:56 PM   #1
muddpile
muddpile's Avatar
Wire harness for a custom?
I was just wondering who makes a wire harness that would suit my truck. When it is done, it will have:
- An aftermarket in-dash CD stereo
- Six Autometer electric streetrod gauges (none mechanical)
- Aftermarket Bright/Dim indicator and signal indicator lights
- Vintage Air heat/cool unit
- HEI
- Edelbrock carb with electric choke
My stock harness is shot, so I have to replace it regardless of what modifications I do to the truck, but I figure I might as well do it right the first time and get a harness that best suits my needs. I've heard lots of people talk about Painless harnesses in the past. Are they a good one and would they work with all the modifications I will be making? Is there anyone else who makes a harness that would better suit my needs, or am I best off just to build my own (not a fun job I'm sure). Thanks!
muddpile is offline   Reply With Quote
Old 10-14-2005, 07:14 PM   #2
matthufham
you won't find a harness with those features. you should just get a 67-72 18 circuit harness with new style fuses. you will be splicing wires no matter what harness you buy.
matthufham is offline   Reply With Quote
Old 10-14-2005, 07:37 PM   #3
53burb
53burb's Avatar
I believe Ron Francis can custom build harnesses...Ron Francis
53burb is offline   Reply With Quote
Old 10-14-2005, 08:49 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
Painless Wiring, only way to go man.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 10-14-2005, 08:53 PM   #5
Blue85
Oilfield Trash
Blue85's Avatar
BTW, talk to Randy70C-10 he has done 2 or 3 installs of the painless kit.
87 Chev 3+3 4x4
Old 10-15-2005, 10:18 AM   #6
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I'm in the middle of my first painless install and I have to say it's been the best money spent so far,it's really top notch and everything is marked.JMO
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 10-15-2005, 10:24 AM   #7
Hart_Rod
Hart_Rod's Avatar
TX 68
What harness did you use? Part #.
Rob
Hart_Rod is offline   Reply With Quote
Old 10-15-2005, 10:33 AM   #8
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Originally Posted by Hart_Rob
TX 68
Rob
#10206,it's the one with the correct ends on it and 18 circut fuse panel
Is it Sunday yet???
68 Project
Old 10-15-2005, 12:16 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used the painless kit for trucks on my blazer and it was a pain imo. I had to cut the fire wall hole bigger and there are wires included that you do not need. Also you need to fill holes in the fire wall cause they are not used(taillight section) the rear taillight harness is not included,the wires are there but no sockets for the lights. Also there is no column harness included.. Just seems like it could have been more complete.. Then agian maybe I bought the wrong one I will have to look at the painless kit # next time I am outside..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-16-2005, 05:02 AM   #10
nitor
Too many projects
nitor's Avatar
Re: Wire harness for a custom?
For the money you probably had to pay for that "Painfull" wiring kit, I would think you should have gotten a complete kit.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 10-17-2005, 12:43 AM   #11
muddpile
muddpile's Avatar
So, for all my custom stuff I am doing to my truck, would painless kit # 10206 be the answer to my problems? Does it have all the bulb sockets and stuff on it, because I have a few of those burned out as well. Also, since I am running electric gauges, will it have provisions for all the separate lights and such, or am I still going to have to fabricate somewhat of a dash harness? Thanks!
