Old 10-14-2005, 08:38 PM   #1
Hart_Rod
Hart_Rod's Avatar
Need help with tilt column rebuild!
I need to change the blinker cam and wiring harness on my tilt column. How do I get the collar off without tearing it up? Any ideas would be appreciated.
Rob
Hart_Rod is offline   Reply With Quote
Old 10-14-2005, 09:04 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
There should be a couple or three screws holding the cam in. Remove them and then once you take the wire cover off the lower part of the shaft, you just pull it and the wires straight out. Oh, you have to take the wires out of the curved harness clip too. Just insert a jeweler's screwdriver into each wire clip in it, and push and they will come right out. Write down the colors to pins first. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
