Old 10-14-2005, 11:41 PM   #1
truckdude239
truckdude239's Avatar
warning light for brake
on my 71 c-10 i have disc brakes in front drum in back no power brakes, anyway my brake light was on when i bought the truck checked the fuild its full pull the wire off p vavle light goes off do i have an bad p vavle?
truckdude239 is offline   Reply With Quote
Old 10-15-2005, 01:18 AM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Mash down on the brakes real hard and the valve should shuttle back to neutral. (Edit: causing the light to go back out.) If it doesn't look for leaks entire system. If no leaky suspect bad master cylinder.
chickenwing is offline   Reply With Quote
Old 10-16-2005, 07:18 PM   #3
truckdude239
Re: warning light for brake
i mashed the brakes hard light still on i know its not the master cylider because if it was i wouldn't be albe to stop lol plus its not leaking on the out side and i don't think it has an internall leak buecause fuild leavel tays the same
Old 10-16-2005, 08:16 PM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
Check the information on this site. I've never tried it. Tell me if does.
http://www.classicperform.com/TechBo...t.htm#testprop
http://www.classicperform.com/TechBo...oubleshoot.htm
A.P. is offline   Reply With Quote
