10-15-2005, 12:30 AM | #1 |
spark plug order
Can anyone supply a plug wire diagram. Its for a 350. I just bought a truck from a kid and i dont think he got them hooked up right.
10-15-2005, 12:51 AM | #2 |
Professional Grade
Firing order is 18436572 Driver's side cylinders are 1, 3, 5, and 7, with number 1 being the cylinder closest to the rad, and passenger's side is 2, 4, 6, and 8, with number 2 being the cylinder closest to the rad.
It doesn't really matter which pole you set as number 1 on the distributer, so long as you set number 1 directly above the rotor's pole. Typically, most people set number 1 as the second pole from place where the power cable goes into the cap, going clockwise Make sure that you have cylinder 1 at top dead center before you do anything though, otherwise your timing will be way off.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 10-15-2005 at 12:53 AM. |
10-15-2005, 01:09 AM | #3 |
You get what you pay for
Here you go. This will make it simple.
Mike 1985 Chevy C-10 |
10-15-2005, 08:37 AM | #4 |
Thanks alot guys. Im going to check the wires, then the timing before i fire it. Gas was shooting out the top of the carb, and the kid I am buying it from is an idiot. I hope he didnt mess anything up too bad.
10-16-2005, 09:17 AM | #5 |
83C10SWB
Re: spark plug order
I had a problem with gas coming out of the top of my Holley when i first got it, it just need adjusted, it was real easy but i broke the gasket that sits under the valve nut and had to make a new one.
Koreric75 2003 Suburban Z-71 4x4 5.3L 83 C10 SWB FOR SALE 350ci/700Raptor Jr Picture&Progress Page |
