07-07-2002, 08:23 AM | #1 |
Drum Brake Locking up, very grabby..
On my 71 (disc front, drum rears) the passenger side rear brake seems very grabby and locks up eaisy. BTW I have power brakes.
I have not had it appart yet, what should I look for? Is there a spring that could break that would cause this?
Rod Childers '71 C10 Stepside |
07-07-2002, 08:41 AM | #2 |
Out of the carpool lane.
Check to see if the passenger side e brake cable is frozen, also maybe the star adjuster isn't doing it's job?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
07-07-2002, 09:46 AM | #3 |
"Ochre Ogre"
When this has happened to me it was a leaky axle seal. The oil saturated brake shoes would lock up the moment the brake was applied. Nobody tailgated me that day!
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
07-07-2002, 11:38 AM | #4 |
its all about the +6 inches
What ever it is, you'll probably notice it as soon as you remove the drum.
07-07-2002, 11:41 AM | #5 |
Well since everyone said everything else....... I would have to say the wheel cyl
Life is good with a 6-71 supercharged 355 in a 72 camaro |
07-07-2002, 02:55 PM | #6 |
It could be the drum brake gremlin!! That little bastard is reaking havioc in my rear brakes!!! LOL!!!!
07-07-2002, 04:36 PM | #7 |
Registered Cruiser
I'm with Brad on this one. Try lubricating your parking brake cables before you do anything else. That's a pretty common problem on these old trucks.
I intend to live forever. So far, so good. |
07-07-2002, 05:54 PM | #8 |
Make sure your wheel cylinders are not rusted solid. Time to pull the drum off and have a look. Da-burb, I had the rear brakes on a truck lock up solid on me from gear oil on the shoes. Be fine except I was on ice and rolling at about 20mph . HAd to leave the beater on an road that turned from snow to solid ice.
Needless to say it got creamed. Wrote off a new taurus though . Good Luck CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
07-07-2002, 07:12 PM | #9 |
Thanks guys, I'll be takin it off tomorrow to check it out. I have had every other wheel off recently and all looked OK. I don't see any kind of fluid, but may have a small leak. Now that you mention it I have seen fluid on tractor breaks and clutches that made them act the same way.
