Old 10-16-2005, 10:31 AM   #1
HOTRODDAD
steering column confusion
i have a lt gray wire hanging out of lower part of column(tilt column) ,it is not in harness , can any one tell me where it goes , & also where does the fuel tank sending wire attach , any help would be apreciated tks hotroddad
HOTRODDAD is offline   Reply With Quote
Old 10-16-2005, 10:34 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: steering column confusion
Gray wire is the light for the PRNDL21 indicator... there should be a spot to plug it to where it'll be controlled by the light switch...dash I think is whatnit says.
Brown fuel tank wire also goes to the fuse box. I am pretty sure there is only one spot that it'll go into.
Old 10-16-2005, 10:42 AM   #3
HOTRODDAD
tks on info on light wie ,but the wire i am speaking of is coming from the sending unit on tank i would think that would have to go through dash cluster for gauge to work if i am not mistaken
Old 10-16-2005, 10:59 AM   #4
jhow66
jhow66's Avatar
Plugs here:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-16-2005, 11:31 AM   #5
Longhorn Man
exactly. It goes through the fuse panel into the harness to your inst panel, that way there is only one big plug to remove/install.. instead of a million seperate plugs.
Old 10-16-2005, 11:56 AM   #6
HOTRODDAD
Tks For The Pic's It Makes A Lot Of Since To Elimanate A Bunch Of Wireing
