10-16-2005, 10:49 AM | #1 |
need the right answer???
i just installed a 3.73 gov lock limited slip rearend behind a 160 h.p. 305 in my 83' gmc. I haven't test drove the truck yet. my question is does the gov lock rearend need the lim. slip additive?????? I have heard many say no and some say yes. thanks. Nice board by the way.
10-16-2005, 11:24 AM | #2 |
Re: need the right answer???
I believe I just used regular gear lube in mine.
10-16-2005, 11:43 AM | #3 |
No No
No, but adding the TransX additive sold for limited slip diffs wont hurt it and its supposed to be a good lubricant for manual transmissions and peg leg diffs. I say spend the 3 bucks extra.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
10-17-2005, 09:56 AM | #4 |
i agree it cant hurt but not nesecery i hav decide myself that synthetics are the way to go and anything more desind for your application IMO should be used
square body trucks an addiction or an investment either way they consume all my extra time and money |
10-19-2005, 06:20 PM | #5 |
thanks i already bought the trans-x i put it in with fresh lube,, no drawbacks as of yet.
10-20-2005, 01:21 AM | #6 |
Professional Grade
I run additive in all of my rear diffs, and standard transmissions.
Also run a special additive in my automatic transmissions.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-21-2005, 02:05 PM | #7 |
Shadetree Mechanic
Yes, you need the additive.
The gov-lok works on friction and if you leave out the friction modifier for very long it will damage the clutch packs and you will not get correct operation. I believe the manual calls for 2 bottles of additive, can't remember for sure.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok |
