Old 10-16-2005, 02:08 PM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
Mounting fuse box and drop rail sealer
Hey, not having any luck with the search function. I have shaved my firewall and am getting ready to install an ez wiring fuse box. Any pics, ideas, etc on making a clean install such as mounting on an aluminum back plane, etc. Any pictures would be appreciated. Also what product do you use to seal a drip rail after it has been stripped and primed. Thanks, Danny
polevault1977 is offline   Reply With Quote
Old 10-16-2005, 03:03 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Mounting fuse box and drop rail sealer
This thread has some good suggestions for drip rail sealer:
http://67-72chevytrucks.com/vboard/s...d.php?t=167024
pjmoreland is offline   Reply With Quote
Old 10-16-2005, 03:28 PM   #3
cdowns
cdowns's Avatar
funny you should ask!! just finished this mount on my hotrod project//i just bent up a piece of steel and will spot weld it to the inside of the firewall//
if you plan on welding on the weekend it's always a GOOD IDEA to check that you have an adequate supply of shielding gas on friday// the welding supply might be closed on saturday
Old 10-16-2005, 03:32 PM   #4
cdowns
cdowns's Avatar
a second
Old 10-24-2005, 08:31 PM   #5
polevault1977
CDowns, thanks for the info and the pics. That is exactly what I was looking for. Danny
Old 10-24-2005, 09:53 PM   #6
72CSTC5
72CSTC5's Avatar
Use the self leveling 3M 8307 self leveling seam sealer.
72CSTC5 is offline   Reply With Quote
Old 10-25-2005, 08:32 AM   #7
72MARIO
72MARIO's Avatar
here is how i mounted my stock fues box. I should have made it a bolt on bracket cause I cant tighten the bolt that holds the outside harnedd to the box. I have driven it 3000 miles now and still no problems thought.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
