Old 10-16-2005, 02:43 PM   #1
GoobersBlueBurban
GoobersBlueBurban's Avatar
Talking TBI vs. Carb
I have a 1987 Suburban 4x4 with TBI. I like the TBI but i also like the tunability of a carb. I wanted to see what some of your opinions are of TBI vs. Carb.
GoobersBlueBurban is offline   Reply With Quote
Old 10-16-2005, 07:30 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: TBI vs. Carb
I guess I'd have to say it's a toss up. I've tuned q-jets but I like the convenience of the tbi I have now. Definetly a big price difference to replace. Of course I'm comparing a 1970 4 bbl q-jet to my current 1989 TBI.
Over on CK5 they have a couple threads on tbi tuning/mods etc....
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-17-2005, 01:17 PM   #3
Tink
Tink's Avatar
Re: TBI vs. Carb
The tuneability of a carb is nice. But, I like TBI for convience, easy of starting, simplicity to rebuild and for me, wheeling... won't stall out on inclines like a carb.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 10-17-2005, 01:25 PM   #4
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: TBI vs. Carb
TBI all of the way for me. Yeah you can tune a carb but the problem is you have to tune a carb. TBI, install it and forget it. Carb = maintenance. A TBI unit is not tempermental to temprature or altitude, and there are no floats to go bad.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 10-17-2005, 11:50 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: TBI vs. Carb
20 Year upgrade in technology
No more dieseling at shut down
No more sticking choke and other linkage
Get rid of the Carb input filter connection
No more leaking / varnished linkage, floats, jets, set screws, etc
Closed loop control of combustion for altitude, gas, engine condition, etc
Module swap repair of system, i.e. , injectors, computers, sensors, etc
Electronic diagnostics
No new Quadrajet carburetors available, no upgrade possible with old system
Technology proven in all modern engines since about 1986
http://www.california.com/~eagle/howell.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-18-2005, 10:08 AM   #6
skillet
skillet's Avatar
Re: TBI vs. Carb
That's a tough one. I have one of each and I like them both. I do like many of the qualities of TBI, such as driveability on cold mornings. I have decided that when I replace my '69 it will be with a fuel injected truck, just as a practical reason of better gas mileage, driveability and less tinkering with the carb. Fuel injection is interesting and I think if someone can work on a carb, he can learn to work on fuel injection. I will go with throttle body injection, like from '87 to '95.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 10-18-2005, 03:18 PM   #7
cdowns
cdowns's Avatar
Re: TBI vs. Carb
fuel injection tho nice / if it craps on you 100miles from home is near impossible to juryrig to limp the 100miles to your garage//carbs the more the merrier
Old 10-18-2005, 06:26 PM   #8
skillet
skillet's Avatar
Re: TBI vs. Carb
That's one of the best points of carburetors and probably the main reason I haven't been able to part with my '69 and go totally fuel injection.
Old 10-24-2005, 08:44 PM   #9
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
Re: TBI vs. Carb
I prefer the simplicity of the TBI system for my stock 87. Although, once I rebuild it with more performance in mind, it would be nice to have the tuning of a carb. Especially with the wideband O2's and readers available now, it's getting easier to tune right in the driveway, with no need for custom chips being burned.
So, I guess stock = TBI, not so stock = carb.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 10-26-2005, 07:32 PM   #10
Russell
Professional Grade
Russell's Avatar
Re: TBI vs. Carb
Tuning a TBI is just as easy, if not easier than tuning a carb
If you can multiply, divide -- You can do up your own chip for your truck with ease
Costs about 60 - 70 bucks to get set up to burn chips in the first place, but that is paid off after two chips.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-26-2005, 08:39 PM   #11
Bob Gervais
Re: TBI vs. Carb
I had no idea it was that cheap to do. Most of the tuning I've been involved with has been newer cars (OBD2), and costs quite a bit to get going.
Got any info on the chip burning stuff?
Old 11-02-2005, 02:28 PM   #12
JonnyTechMech
STOP! Hamma time!!!
JonnyTechMech's Avatar
Re: TBI vs. Carb
I second that request!!!
Plan your work and work your plan!!!, or pitty da fool!!
87 GMC BaseTrim, 305 under the wrench/TH400/
92 Chevy 1500, 350,TH700R4 sittin on dubs
JonnyTechMech is offline   Reply With Quote
Old 11-02-2005, 05:38 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: TBI vs. Carb
http://www.passtimeracing.com/eric/Cars/EFI/index.htm
http://www.tunercat.com/
http://www.xtronics.com/memory/EPROM.htm
http://www.fullsizechevy.com/forums/...5&page=1&pp=20
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-03-2005, 11:10 AM   #14
JonnyTechMech
STOP! Hamma time!!!
Re: TBI vs. Carb
Thanks Captkaos,
I love this board!!!!!
Old 11-03-2005, 12:51 PM   #15
Captkaos
Captkaos's Avatar
Re: TBI vs. Carb
No problem.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-02-2005, 06:10 PM   #16
junkyardpartseeker
Re: TBI vs. Carb
how hard is it to go from carb to tbi on a 84 suburban? thinking of doing it to mine. It has a 350 with a quad on it now.
Tommy
junkyardpartseeker is offline   Reply With Quote
Old 12-02-2005, 06:21 PM   #17
skidder
Re: TBI vs. Carb
Junkyardpartseeker: For a factory setup you will need an 87-91 fuel tank c/w in tank pump, the tbi intake, computer, and harness. The supply fuel line will need to take up to about 15 psi and a return fuel line is required(there is probably already one there). I put this system on my 72 Blazer an I am happy with the results.
skidder is offline   Reply With Quote
Old 12-02-2005, 06:22 PM   #18
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Re: TBI vs. Carb
I like the TBI vs the carb. I am going to change the motor in my Daily driver. It has a 305 TBI now and I will be putting in a 350 TBI. A friend of mine said go carb you will get better performance. While that may be true I LOVE the reliability of the TBI and it will stay for a DD truck.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-04-2005, 11:15 PM   #19
87 GMC
87 GMC's Avatar
Re: TBI vs. Carb
Convert it to mulit-point, my both of my TBI trucks are haunted.
87 GMC is offline   Reply With Quote
Old 12-07-2005, 12:48 AM   #20
screwballl
Tonawanda 454
screwballl's Avatar
Re: TBI vs. Carb
if you have extra parts around like many of us do, it would be wise to bring along some sockets and an extra carb for your engine, something that will get you another 50 miles to town for TBI parts or diagnostics... just keep it sealed in a box or something in a hidden compartment or behind the seat...
always have a backup.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 12-09-2005, 02:16 AM   #21
84 400
Sb 400 club
84 400's Avatar
Re: TBI vs. Carb
myy bbuddy has a 94 gmc 1500 and hates his tbi. if i were going to mess with the computers and such i would go mutie point but that is pricey. I love my carb but hat the warm up factor and tuning can be a pain but with the right tool it is a breaze. nall opion. and with a carb the motor is not as fuel effisent. if i were u i would stay tbi cause u have the comp and all.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
