Old 07-07-2002, 11:46 AM   #1
nosto
Flamin' Bass
nosto's Avatar
Question Bags and driveshaft endplay - help!
After 6 months of bodywork, I'm finally starting to reassemble the truck.
This is the first time I've put the driveshaft back in and at first it wouldn't go in. Then I filled the rear bags and was able to hook the U-joint on the rear. At this point the shaft has about 1/2" endplay. But when I dump the air, the shaft slides forward into the tail of the 4 speed Muncie so there's no noticable endplay left.
QUESTION: What's the minimum endplay (front to back) for the single piece driveshaft?
I CAN slide the motor (350) forward a bit, about 3/8" slop in the motor mounts, but I gotta drill new holes for the (kludged) tranny crossmember. Don't wanna if I don't hafta.
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 07-07-2002, 11:49 AM   #2
REPO1
Shortbox wanna-be.
REPO1's Avatar
Personally at the lowest point where it shoves the shaft in, I would try and keep a minimum of 1/2" movement in the shaft.
Why not figure out exactly how much you have, then have you driveshaft shortened a bit if the need be.
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
