72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
72 3/4 Ton Rear Axle
Are new U-Bolts available??? If so, who has them? Links??? ![]() Thanx!:
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
Cantankerous Geezer
Re: U-Bolts Rear Axle 3/4 ton
If there's a spring shop in your area, they should be able to make them if you take one for a pattern.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#3 | |
The *bling* option:
http://www.offroaddesign.com/catalog/uboltreversal.htm An upgrade, too, since the u-bolt threads get outta the dirt, rocks, mud that ruins the threads for the next time they are removed. From what I've read, one can source used 73-? rear u-bolt spring plates cheap and add either spring shop made u-bolts or store bought u-bolts for $20-$40. I've found plated Trailmaster u-bolt kits with tall nuts for <$15 per pair. Used 73up rear u-bolt plates should <$10. ORD's fine kit comes with powder coated plates and zinc plated, Tuff Country u-bolts (TC part #17706) with tall nuts and thick, grade 8 washers. Quality stuff in one kit.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 10-17-2005 at 05:07 PM. |
