10-17-2005, 06:23 PM | #1 |
1987 Transmission fluid leak?
Does anyone know if there is a recall or anything for the following issue:
I am leaking trans fluid from my driveshaft yoke going into my transfer case(4X4) The fluid appears to be comng out of a weep hole in the yoke itself and is leaking on to the u joint? Anyone e3ver have the same problem, or know of a fix? Thanks for any help!! Dan |
10-17-2005, 06:33 PM | #2 |
LED King
Re: 1987 Transmission fluid leak?
It is a simple o-ring that needs to be replaced. Fairly common.
See here for a fix: http://www.73-87.com/7387garage/drivetrain/yokeleak.htm
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
10-18-2005, 12:32 AM | #3 |
Insert Witty Text Here
I have done the fix on my TH-350C. It was pretty easy, at least on the 2WD.
Slonaker |
10-18-2005, 07:30 PM | #4 |
Thanks guys..looking into it.
