Old 10-17-2005, 06:59 PM   #1
Boydness
Projects follow me home...
Boydness's Avatar
Question Can anyone ID this rearend?!
Recently bought the 72 Chevy and it came with this rearend. I have had the hardest time locating parts for it. Found 13" brakes for it, but can not locate the retaining rings for the hubs.
Any ideas?
It has 8 bolts in the cover with two on each side close to each other in line with the axle.
(Not the cleanest it could be, but it took me forever to remove enough mud to at least show the features.)
Boyd
Boydness is offline   Reply With Quote
Old 10-17-2005, 07:03 PM   #2
FormerMember
Re: Can anyone ID this rearend?!
Eaton. Good solid axle.
HO model, can't quite grab the model #'s
FormerMember is offline   Reply With Quote
Old 10-17-2005, 07:08 PM   #3
'71c204x4454
'71k204x4454
Here is a good thread on this subject. Almost more then you want to know.
http://www.67-72chevytrucks.com/vboa...d.php?t=172827
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 10-17-2005, 07:11 PM   #4
Boydness
Boydness's Avatar
Thought it was an Eaton, but no one could tell me anything about it...
The numbers on the short side are: 3766686 (?) 28 "Wheel" D
Does that sound right?
Old 10-17-2005, 07:22 PM   #5
Boydness
Boydness's Avatar
Also forgot to mention that it is a dually, if that makes a difference...
I am guessing that it is a 1-ton Dually Eaton H072 That sound right?
Old 10-17-2005, 07:59 PM   #6
FormerMember
HO74 (I think... might be HO72 as I get them confused with the HO52) then.
all dually I've seen with an Eaton have been HO7x.
<-- is Captain Lysdexic
Old 10-17-2005, 08:11 PM   #7
Boydness
Boydness's Avatar
I will call around tomorrow, now that I have an idea of what I am actually looking for...
Old 10-17-2005, 08:36 PM   #8
dwaite72lnghrn
It's not an H072/h11 as it does not have the ring stabilizer bolt on it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 10-17-2005, 08:43 PM   #9
FormerMember
Do you think someone swapped it in and converted it to a dually?
I thought all duallys were HO72?
Old 10-17-2005, 08:48 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is not an HO72...it has coil springs. This is a C/20 isn't it? That would make it an HO52.
NO one tons came with coils, and the one ton is the only way to get an HO72.
Grendel, forgive me, I am having problems remembering your truck... is it the maroon GMC duallie witht he fleet bed and step side fenders attached? If so...yes...DEFINATLY an owner modified rig. No daulies came with beds... none in 3/4 ton trucks, and another point of interest... the extra tires were inboard of the hubsm not poutboard. The track width was i9ncreased by an inch or two instead of by a foot or so on the later rear ends found under daulies.
Old 10-18-2005, 02:38 AM   #11
4x4Poet
Originally Posted by Boydness
Recently bought the 72 Chevy and it came with this rearend. I have had the hardest time locating parts for it. Found 13" brakes for it, but can not locate the retaining rings for the hubs....
Do you mean the two hub washers that have a tab on the inside circle and slide onto the spindle to either insulate the bearing from the lockwasher or the locknut from the lock washer? If so, the dealer still sells them. For my '72 SRW H052, I recently picked up a hub washer at my local dealer:
3663658 Washer $5.25 each.
I can't say for sure that they will fit your dually setup Eaton. Take an old one with you. Have a good look at your lock washers, too, since the dealer likely carries them, as well. I couldn't find either at local auto parts stores.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-18-2005, 02:46 AM   #12
masterbeavis
Having issues
masterbeavis's Avatar
I read that some of the HO axles did not have the ring gear bolt chingadera. Check out the bootie fab welding job mounting the springs to the housing. Looks safe, Id run it!!
[edit]
Looking at the entire axle helps some.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 10-18-2005, 06:27 AM   #13
Boydness
Boydness's Avatar
Not sure why the coil springs were added, but they are not OEM or anything.
Old 10-18-2005, 06:53 AM   #14
I was going to mention the non-original nature of those coils.They are added as auxilary to the leafs?It sounds like your question is answered.But,can we get more pictures of theaxle set-up and truck?
Old 10-18-2005, 04:36 PM   #15
Longhorn Man
Yowzers.... how did I NOT notice the total LACK of trailing arms???
Old 10-18-2005, 04:53 PM   #16
FormerMember
BTW, this is NOT my truck.
I wish I had the dually with the bed...
Mine is a dropped C10 these days, but I've had a few 67-72's in my life.
Old 10-18-2005, 05:14 PM   #17
Boydness
Boydness's Avatar
Thumbs up Re: Can anyone ID this rearend?!
Turns out what I was looking for was:
3663659 LOCK $5.66
I went ahead add replaced the 3663658 WASHER $5.64 also.
I tracked them down at R.K. Chevrolet after calling around a bit.
It was a lot easier actually knowing what you are looking for and to be able to give someone a part number. Thanks alot 4x4Poet
Fortunately Grendal confirmed that it was an Eaton, so that I could at least stop looking up every other type.
Why does everyone else got to hate?! (cough cough Longhorn Man & MasterBeavis)
It's a POS, but at least it's my POS.
LOL, just kidding, it's a truck that I bought to haul my little projects. It has come to be another one of my projects. My buddy that helps me (read: does most of the work) doesn't care too much for it right now.
I will take some pics of it, but it is nothing to look at right now...
Boyd
Old 10-18-2005, 06:35 PM   #18
Boydness
Boydness's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=177268
Old 10-19-2005, 04:13 PM   #19
Boydness
Boydness's Avatar
I was just kidding about the stuff all.
Feel free to make fun of or comment about whatever you think is wrong or funny about my truck/stuff. I don't take any of it serious. But, be sure to tell me how to fix/replace/destroy whatever it is also...
Boyd
