Old 10-17-2005, 07:04 PM   #1
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Lightbulb Single wall top question
I was in Utah this weekend picking up some toner for the Jimmy when I ran into this local guy who turned me onto a nice single wall top which I promptly bought and dragged home to Calif.
My question is this; Anyone ever have a look at the inside of one of these? It sure looks to me like they are more than 'one peice'. That observation would include the top portion. What do you think?
Thanks in advance...Tpm
Tom Vogel is offline   Reply With Quote
Old 10-17-2005, 07:11 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Single wall top question
I'm not a expert on singles, but pic's might help me learn more about em
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-17-2005, 09:04 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
i am just taking a guess here but i think a single wall top it in all reality has 2 layers of fiberglass to them( and inner and outer) there just closer togeather than a double wall the double wall, a double wall has the same but they are spaced farther apart hence the double wall part of the name
tnblazerk5 is offline   Reply With Quote
Old 10-17-2005, 11:25 PM   #4
jamie72
jamie72's Avatar
yea they are 2 layerd, they even have some metal in it in high stress areas for support.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 10-17-2005, 11:32 PM   #5
RunTMCfan
RunTMCfan's Avatar
When I joined recently I was complimented on my single wall top. I was very thankful for the compliment. I can't remember what my old top looked like in my 70'. This is from my 72' that I acquired recently and like I stated before it was called a single wall. It looks like it has a number of pieces to it.
In my first post I stated that the top would score an 8 out of 10 but it's showing cracking at the seems.
What I'm getting at here is that I don't know why it's called a single wall.
Rob
RunTMCfan is offline   Reply With Quote
Old 10-18-2005, 01:37 AM   #6
71jimmy
71jimmy's Avatar
They are referred to as single and double because they ARE different and its an easy way to understand.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-18-2005, 07:26 AM   #7
Huck
Huck's Avatar
Tom, both the single and double wall tops were manufactured from many pieces, including metal framing and fiberglass sections. I doubt that either would protect anyone in a rollover thus the option for a "roll bar" from the factory!!!!
If you look at a top closely, there are seams all over the place that were filled at the factory. Over time, the stress and aging process results in the seams showing as the filler cracks a bit. This is not a structual problem. If your cracks are straight lines or manufactured curves, then you can see the sections. In restoring, you can simply remove the old seam filler, re-fill with a non shrinking, semi-hard caulking, and repaint. If you have fiberglass cracks that are jaggered, then you may have a structual issue to repair. Both single and double wall tops are heavy and should show no flexing if good. Double walls tend to go concave on the roof so beware. Can't tell you how many tops I've seen where someone tried to remove without removing the mounting bolt that goes through the sunvisor mounting bracket only to break out a corner of the top!! Huck
Huck is offline   Reply With Quote
Old 10-23-2005, 08:29 PM   #8
jhow66
jhow66's Avatar
"double wall tops tend to go concave" ---any way to fix this condition?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-02-2005, 07:39 AM   #9
smbrouss70
smbrouss70's Avatar
My singlewall is slightly concave too. So any info on how how to fix would be greatly appreciated.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-02-2005, 06:18 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I had a boat shop look at mine, they said they could fix it, but
right now I don't have the greenbacks for the job, one member
here, bobbyk, did a real nice re-paint on his, might be in FAQ
Old 11-02-2005, 08:14 PM   #11
krue
Designated A-hole!
krue's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=146442
This might help?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-03-2005, 01:25 PM   #12
70rs/ss
70rs/ss's Avatar
I do not know if this is PC but I put expanding foam in mine and the sag dissappeared. It is much quieter and evn more solid to remove. I had a copule of holes in my top so I speyed the foam in and covered the holes with tape. I day or so later the sag had risen and I patched the holes with fiberglass. If you do not agree with my method that is OK, it is just the way I did it and it worked excellent for me, try it and you be the judge. BTW it cost like $20 to do it, and in my opinion it was worthit and I do not have a fortune in my top.
70rs/ss is offline   Reply With Quote
Old 11-03-2005, 04:50 PM   #13
jhow66
jhow66's Avatar
Thanks for the reply 70'--that was just what I wanted to know(if anyone had tried it). That what my son (orangeuavol) was considering.
thanks-jhow66
Old 11-03-2005, 10:50 PM   #14
Pop's72
It's ok to stare...
Pop's72's Avatar
The PO for mine also used expanding foam. As he described it, he and his friend cut 3 holes along the center of the top. They then sprayed in the foam until the sag was gone going from hole 1 to 2 to 3. I think he said they had a friend push from underneth the top to make sure the "sag" went the right way (not sure about that). Giving it a day to "rise" like 70rs/ss did sounds like a good idea to me.
Pop's72 is offline   Reply With Quote
Old 11-03-2005, 11:31 PM   #15
krue
Designated A-hole!
krue's Avatar
If it works, it works.
www.daveramsey.com
Old 11-05-2005, 07:37 PM   #16
RunTMCfan
RunTMCfan's Avatar
True that. Can't argue a cheap and easy fix that works and looks good. Hmmm if only our politicians subscribed to this.
Rob
Old 11-05-2005, 07:47 PM   #17
krue
Designated A-hole!
krue's Avatar
www.daveramsey.com
