Need some help with swap PLEASE!!
I have a 5 lug crossmember out of an 81 1/2 ton 2wd Chevy to put in my '70 2wd. I was wondering if there are 6 lug rotors available anywhere. The reason why I am wondering is because I got 5 lug rear axles out of a '77 gm van 12 bolt and they are longer thn my 12 bolt 6 lug axles. So if anyone knows what year and model 12 bolt rear end that I can pull 5 lug axles out of that will fit my '70 12 bolt, other wise I am going to leave the rear 6 lug and try to change the crossmember to 6 lug.
Thanks in advance for helping me with my mess.....Terry ![]() |
"Bondo, just say no!"
Re: Need some help with swap PLEASE!!
I need help with this 5 bolt rear end issue as well I was going to try the 87 2wd chev pickup one that that i got the front crossmember from, but I'm still waiting for a buddy to bring it to me in a couple days.
CAN ANYONE HELP US we should try this question in the message board
"WORK NOW, SLEEP WHEN I'M DEAD, SPEND EVERY PENNY I MAKE" 69 C-10 SWB Stepside (ground up resto in progress) 86 Yugo 69 Honda pc50 moped see my work @ http://www.myspace.com/inkorperated free site for pics |
![]() Join Date: Aug 2003
cpp has the rotors you need. they use 73-87 spindles. www.classicperform.com as far as the rear end goes, you could get a conversion kit with the saddles for the trailing arms but cutting and welding is involed. might be easier to get just the rotors.
Outlandish Trends - FL
Early Classic has an axle conversion kit for the rear. Not sure if it'll work with your housing but it should. Give them a call, or check out www.earlyclassic.com
-Bret 67 short-fleet sold! |
Just Don't Stop!
![]() Join Date: Feb 2004
You can always have a machine shop re-drill your 6 lug axles for 5 lug also...
1968 C10 build in process TT LSA/6L90e/9" |
Don't know if this will help much but I owned a 1965 Chevy Truck which I switched the front over to Disc and also had five lug rotors. The front clip used was out of a 72 Chevy. I did some looking and the bearings for the rotor were identical size to that of a 3/4 ton. I took my 5 lug rotor to Autozone and compared it to a 1999 or 2000 Chevy 2WD 3/4 ton 6 lug rotor and found a match. I should say that the bearings matched. The rotor was possibly 1/8 of an inch smaller in diameter so I do not know how that would have worked or if it would have at all. I have to apologize though, I do not have all of the info of the truck I pulled the front clip off of since this was the first project I ever attempted a long time ago. I sold the truck before I ever decided to go through with it and try it out. If nothing else, it is worth a try. It could save you $$$. (Not always the best thing to do) If you have any questions let me know and I will see if I can help out.
Jay Last edited by jfarnbach; 10-20-2005 at 04:36 PM. |
crossmember with 6 lug front disc brakes
I was wondering if any 73-87 trucks came with 6 lug front disc brakes, I wanted to swap out my 69 front crossmember for a 6 lug with disc brakes.
#8 | |
Just Don't Stop!
Re: crossmember with 6 lug front disc brakes
No they did not, that's the only reason we are talking about this swap. They do make a conversion aftermarket rotor that will give you 6 lug on a 73-87 spindle but if they ever stop producing them or if you need one quickly you are kinda screwed...
