10-18-2005, 01:20 AM | #1 |
What's a cheap header for my big block (4x4) 1 ton?
I'm looking for a set of cheap headers for my big block truck. What should I look at. Also, it's 4x4, if that matters.
10-18-2005, 01:25 AM | #2 |
Re: What's a cheap header for my big block (4x4) 1 ton?
Also, its a 1 ton.
10-18-2005, 08:05 AM | #3 |
I Used Hedman Hedders On My Half Ton With A Big Block. They Were A Good Price. Primary Tubes 1 And 2 Go Up And Back To Help Clear The Frame Rails. If You Use The Standard Down And Back Primary Tubes You May Have To Notch The Frame Rail For Extra Clearence During Block Torque. I Learned The Hard Way And Installed A Set That Just Fit. The First Time A Stomped The Peddle, I Bent A Primary Tube. Hope This Helps.
