Old 10-18-2005, 12:32 PM   #1
MrC1
Dork For Days
MrC1's Avatar
Question 1.5" Drop Shackles - Install tips?
I just got some 1.5" drop shackles from Classic Industires to level the ride on my '72 C20. Anybody got any tips on installing these things?
I believe the process is as simple as:
0) Disconnect negative battery cable.
1) Lift the truck by the frame, so the rear suspension is unloaded.
2) Unbolt the shackle, bolt in new one
3) Admire work
Is there anythign in there I should be aware of? I guess I'm mostly wondering if there's going to be any load on the leafs when I go to unbolt them. Also, for the same reason, is bolting them back up a simple process, or will I need to pry on them to line things back up?
MrC1 is offline   Reply With Quote
Old 10-18-2005, 02:29 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
Re: 1.5" Drop Shackles - Install tips?
When I put mine in I jacked up the truck to take the pressure off the rear leafs. You can tell when the pressure's off by how easily the shackle bolt comes out. If the bolts are rusted they can be tough to get out. Better to lift a little too high than not enough since the springs store a bunch of energy when loaded.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-18-2005, 02:53 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Here's what I do:
1.) jack truck up and put jackstands under frame on either side so you have your floor jack free.
2.) put the floor jack under the rear diff. Give it one pump after it touches the diff just to take a little weight off and prevent anything from falling on you while you're under there.
3.) unbolt stock shackle. I start at the leaf bolt first, remove that, then go to the upper bolt to the frame.
4.) Reverse steps to put new one in. You can move the axle up or down by using the floor jack under the diff so you can play with different heights to get it in.
The whole job should take you about 30 minutes. Maybe more if you've got rusted bolts that are a PITA to get out, but it's a simple job.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-18-2005, 03:59 PM   #4
MrC1
Dork For Days
MrC1's Avatar
Thumbs up Re: 1.5" Drop Shackles - Install tips?
Thanks guys - kinda what I was thinkin. This should be a fairly painless job.
Old 10-24-2005, 03:21 PM   #5
MrC1
Dork For Days
MrC1's Avatar
Angry Dangit!!
My truck is a 99% rust-free Oklahoma truck, so I didn't expect any problems. Well, turns out one side is completely seized up. The psgr side went in with only minor modification to the aftermarket piece (using a grinder). Teh driver side was a bit different.
I managed to get the upper nut off after about 20 minutes of wrenching. The bolt itself is completely seized up, however and my impact won't touch it. The lower bolt is that way on both the nut and the bolt.
I'm planning to get a local 4x4 shop to take a look at it and probably burn out the rear leaf bushing with a torch. Anybody got any other recommendations?
And no, a 3-foot pipe won't budge it either!
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
