cutting coils?
Do you cut the top or bottom?
Aaron |
Outlandish Trends - FL
Re: cutting coils?
Cut the middle
-Bret 67 short-fleet sold! Last edited by 67Fleet; 10-19-2005 at 08:16 AM. |
#3 | |
Re: cutting coils?
You are way better off buying new lowered coils, as when you cut the coils you increase the spring rate and really stiffen the ride. My .02 cents mike |
Saving 1 truck at a time!
Re: cutting coils?
Cut the bottom of the front coils since the top of the coil fits over a sheet metal boss to keep it centered. You can't cut the rear coils since they need both bosses to mount them to the frame and trailing arm. You can heat the rear springs to make them sag. Old school guys have been doing it for years.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#5 | |
Re: cutting coils?
Aaron |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: cutting coils?
You have to cut the bottom. The top is pigtailed, the bottom is not.
1 coil equals about 3 inches. I've cut a bunch of them and been happy with the results. Cut em first, if you're not happy, then buy drop coils.
Re: cutting coils?
On the rear I just heat them with a torch in the middle. I move it around to different locations to try to even it out a bit. Once it starts to sag you have to watch it closely to make sure you drop the same on either side. I have run coils like that in hotrods for years without any problems. I don't use them as daily drivers though. This is a cheap fix when you don't have the cash. I am running bags now and really prefer them since they are infinitely adjustable.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 10-18-2005 at 05:21 PM. |
#8 | |
Re: cutting coils?
![]() Aaron |
Please read this.....
DON"T heat your coils. If you can't afford to do it right, wait.
http://67-72chevytrucks.com/vboard/s...d.php?t=172761 The only way to control the amount of drop when heating coils is to place a fixed object (like a block of wood) under the suspension so it will only collapse a certain amount.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-18-2005 at 08:14 PM. |
Your UncleBen
![]() Join Date: Dec 2002
Re: cutting coils?
Cut from the bottom...Once you get them out you will see why.
![]() lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
