Old 10-18-2005, 02:57 PM   #1
1-PU70
1-PU70's Avatar
Centering Steering Wheel ?
When you center the steering wheel by adjusting the tie rod sleeves, without changing the toe do you turn them the same direction or in oposite directions?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 10-18-2005, 03:13 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Centering Steering Wheel ?
Put the wheel where you want it and turn the sleaves (as you turn them the wheel will either go in or out and then you can go the direction you need).
mike
70rs/ss is offline   Reply With Quote
Old 10-18-2005, 04:57 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You have to lengthen one and shorten the other.
