Old 10-19-2005, 08:39 AM   #1
chevybill
chevybill's Avatar
Talking Timing a vortec motor- please help
Here is the situation,
I have a vortec motor from a 98 tahoe that I am converting to carburetor and no computer stuff.
The harmonic balancer only has one groove on it and the timing cover has no timing tab like the old motors.
When I get it back in the truck, how do I get it timed, other than bringing up no 1 under compression and dropping in the distributor.
Do the distributors from summit need another dist gear? I know i need a "melonized" gear or a gear for the roller cam.
Any suggestions on timing are much appreciated.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 10-19-2005, 10:19 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Timing a vortec motor- please help
Get an adustable timing pointer. They bolt on using two timing cover bolts. Since you already have a balancer, and probably don't have the bucks for a degreed one, get either timing tape or a balancer cover that is degreed.
Best way to find TDC so you can set the pointer is with a degree wheel and a piston stop.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-19-2005, 10:36 AM   #3
chevybill
chevybill's Avatar
tell me more about the degreed cover, the vortec has a different looking timing chain cover.
Old 10-19-2005, 07:10 PM   #4
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
I installed a 96 vortec motor a few years ago in a 72 C-10 and ended up putting on an old style metal timing chain cover with degree marker. As I recall, the vortec cover was a composite material and had some kind of crank trigger port at the bottom. This on it's own was going to be a possible problem. There also may be a clearance problem with the vortec cover and the short water pump.
Dual quad is offline   Reply With Quote
Old 10-19-2005, 07:48 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Balancer cover, not timing cover. Like this one
http://store.summitracing.com/defaul...=KeywordSearch
And this is an adjustable timing pointer
Fred
Old 10-19-2005, 08:44 PM   #6
chevybill
chevybill's Avatar
thanks for the links, great information.
did you use a timing cover for like a older 350 (up through 1985)?
