Old 07-07-2002, 06:02 PM   #1
Durwood
Durwood the Dillweed
Durwood's Avatar
Question Heater Valve Woes
So, I have an A/C cab with no A/C. All that's left in the engine compartment is the drier. There is no heater valve, as there isn't any vacuum to control it, so the hose goes straight to the core. Even when the fan's not on, that stupid thing is pouring heat into my cab, and it's the middle of summer...
What can I do? Do the non-A/C trucks have a manual heater valve or are they vacuum controlled, too? Any suggestions?
Thanks!
OleBess :: 69 V8 LWB 3-on-the-tree falling-apart-but-ya-gotta-love-her daily driver
Durwood is offline   Reply With Quote
Old 07-07-2002, 06:19 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
Take the heater hoses off the Core, and use one of them to loop the system bypassing the core for now, and then figure out what is going on with the switch. Not a fix, just a bandaid to keep you from boiling for now.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 07-07-2002, 06:48 PM   #3
mark25
you can go to your local parts store and get a manual shut off valve for your heater that goes in line to stop water flow to the heater core. i had the same problem with the vacuum operated water valve so i put in the manual valve and no more heat in cab!!
'72 C-10 Cheyenne Super, 402/TH400, Bucket Seats, tilt, tach, AM/FM & shoulder harnesses and a ground up restoration
mark25 is offline   Reply With Quote
Old 07-07-2002, 07:08 PM   #4
jlmtrout
Non a/c trucks have a valve inside the "doghouse" controlled by a lever on the control panel(middle lever labeled heat) and a cable similar to a manual choke. Good luck and keep on truckin'!----Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
