Old 10-19-2005, 04:26 PM   #1
72orangepumpkin
Father of a Chevy Boy!
72orangepumpkin's Avatar
Horn Button Assembly????
Does anyone have pictures of a complete horn button assembly for a 72? or better yet step by step photos? I have looked at the kits for rebuild for the 3 spoke aftermarket wheels in "chevy duty" etc. and they all have a spring, but I have a stock wheel and no spring. Is there supposed to be one for my year? If so anyone know where to get one? I'm very confused... Please Help.
Thanks, Chris
72 Chevy 4x4
Restoration in progress!
72orangepumpkin is offline   Reply With Quote
Old 10-19-2005, 04:58 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Horn Button Assembly????
I don't have any pictures, but you should have a spring of sorts in there. It looks more like a large thin washer that is shaped kind of like a satellite dish. It goes in your steering wheel horn button cavity first, followed by a plastic ring with three cylindrical sections attached to it that the three mounting screws go through.
pjmoreland is online now   Reply With Quote
Old 10-19-2005, 06:40 PM   #3
72orangepumpkin
Thanks for the help so far...Is the "spring of sorts" round washer the same diameter as the cavity? or smaller?
72 Chevy 4x4
Old 10-19-2005, 06:44 PM   #4
MrC1
Dork For Days
MrC1's Avatar
Lightbulb Re: Horn Button Assembly????
This may not be a popular answer (haha), but take a look in a LMC catalog. They have some really nice exploded diagrams that will probably be just what you need.
MrC1 is offline   Reply With Quote
Old 10-19-2005, 08:24 PM   #5
pjmoreland
pjmoreland's Avatar
The spring washer is pretty much the same diameter as the horn button cavity and has holes in it. Not only does it act as the spring, it also provides the electrical connection for the horn signal when you press the button.
Old 10-19-2005, 08:31 PM   #6
72orangepumpkin
After reading replies, looking at an LMC catalog and doing a little digging I think I have all the parts, Now just need to figure out installation order. So just a few more questions...
Does the nylon ring go in before or after the spring plate?
Does the ring nylon ring lay flat or do the little posts go down?
Does the spring plate (shaped like a satalite dish) go with the curve in or out?
Obvious first timer here, appreciate all the help.....
72 Chevy 4x4
Old 10-19-2005, 09:49 PM   #7
pjmoreland
pjmoreland's Avatar
I believe the convex side of the spring plate should face you, but I might be wrong. If your horn stays on all the time, then it's probably backwards. You should be able to figure out the correct orientation by finding the spot on it where the little spring post that comes up through the steering wheel from the steering column has worn a dull spot on it.
Next you install the cup that the horn button attaches to (orient so horn button will fit in notch).
Then you install the the nylon ring with the posts down.
Then install the screws.
Old 10-19-2005, 10:37 PM   #8
72orangepumpkin
Thumbs up Re: Horn Button Assembly????
Thank You! That makes sence, I looked in the LMC catalog as suggested by another member and it gave a good diagram so I was able to find all my parts but it showed the nylon ring going in first, before the spring and I couldn't figure out how the whole thing was held together. Does it make you feel good to know you saved the day? Thanks again... Chris
72 Chevy 4x4
Old 10-20-2005, 02:43 AM   #9
ChevyMex
ChevyMex's Avatar
Is a pain in the a... when you do not know hot to do it right the first time, please take a look into this diagram. Upssss, i can not post any images...
ChevyMex is offline   Reply With Quote
Old 10-20-2005, 09:07 AM   #10
MrC1
Dork For Days
MrC1's Avatar
Talking Re: Horn Button Assembly????
Let's all dance to celebrate his success!
Old 10-20-2005, 09:12 AM   #11
truckdude239
truckdude239's Avatar
now i need to get mine working lol its an apc steering wheel how do i run the wires thought the columon?
truckdude239 is offline   Reply With Quote
