![]() Join Date: Dec 2001
Backup light switch question
Just installed Hurst 3 Speed shifter,had to get a backup light switch.I wanted to use the wires from stock switch to tie into,problem is don't see any wires to the transmission.Since this was 3 on the tree,could the wires and switch be in the column? Also how do I wire this switch up if I can't use factory wiring?
Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
Re: Backup light switch question
ttt
#3 | |
BTW .....Why did you put a floor shifter in??
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB |
Shifter tube gone out.Figured I would go ahead and put in the floor.It was going to cost about the same after parts and labor.Thanks for the info.
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 10-19-2005 at 11:47 PM. |
![]() Join Date: Sep 2005
where did you get your back up light have an 71 that was converted to 3 speed in the floor befor ei got it and i don'ty have back up lights lol
If it is a Hurst shifter you will need backup light switch and bracket,Hurst part #2480003 about $25.00
