Old 10-20-2005, 10:48 AM   #1
mrgoodwrench_420
Where Ti Find Hump For Bigger Trans
I Need To Know Where I Can Find This Hump People Told Me About To Make My T5 Fit In My 68 And Does It Weld In Or Bolt In And How Much Do I Need To Cut Out Of The Floor
mrgoodwrench_420 is offline   Reply With Quote
Old 10-20-2005, 10:58 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Where Ti Find Hump For Bigger Trans
Check the parts board for a "high hump" tranny cover. You will have to cut the old low hump cover out ane either screw, weld or rivet the new high hump into place. The high hump came with big block trucks and with 4x4 trucks I believe. Someone will correct me if I am wrong.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-20-2005, 12:03 PM   #3
cdowns
cdowns's Avatar
it's easy enough to take a piece of sheetmetal and make one //it's called fabrication
Old 10-20-2005, 03:16 PM   #4
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Both 4wd and 2wd trucks with the top loader 4 speed (SM-465) have the high hump transmission tunnel.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
