Old 10-20-2005, 02:59 PM   #1
6T8
Active Member
Body mounts original or poly
Going to be putting new body mounts on 71 blazer/truck project. Wondering pro's and con's. Do poly mounts give too stiff of a ride? Originals were good enough for 30 yrs, just stay with them? I'll probably use poly on suspension. Best place to buy from vendor on this site. Thanks for any input.................Rick
6T8 is offline   Reply With Quote
Old 10-20-2005, 06:16 PM   #2
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Re: Body mounts original or poly
I ordered poly from summit for the blazer as I want body/frame as tight as possible.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 10-20-2005, 07:16 PM   #3
BigMike
BigMike's Avatar
I have used Poly bushings in a 67 Nova (and a couple VW Bugs) and everyone of them SQEEEEEEEKED, it drove me nuts. I tried installing them with lube but, that only lasted a short time before the freakin Canaries came back. I am not sure about the cab bushing but, the suspension stuff is not worth the sqeeking IMO.
I ordered stock bushings for my truck. You will more than likely get more road noice and feel the road more with Poly over the stock rubber ones.
Mike
BigMike is offline   Reply With Quote
Old 10-21-2005, 01:52 PM   #4
6T8
Active Member
Talked to a local guy who bought some parts from me. He said poly mounts will cause body to crack around mounts if doing alot of 4wheeling. I'm going with original. LMC has complete kit with bolts, will have to check if anyone else has. Thanks for all the help everyone.........Rick
Old 10-21-2005, 04:45 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've always run new GM OEM cab mounts with no problems at all.
This last truck, I bought a set of rubber aftermarket mounts from a vendor and they cracked and split already. They've been installed since March, that's it.
I'm going back to GM mounts from now on, no more aftermarkets for me.
