gauge cluster swap
I have an 87 blazer with the idiot lights dash and i want to swap to gagues.Anybody know what wores need to be moved around on the connector?I was told it was a plug and play deal(with sender swap as well)but the temp gauge moves with the left singal light indactaor
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: gauge cluster swap
Definitely not a plug and go swap. I use a Haynes manual for swapping.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Oh,you can't buy that new
![]() Join Date: Apr 2000
different wiring behind the cluster. I'm SUPOSSED to be the dash guru here and the last IDIOT light swap i did ,on a truck to sell, i actually installed all cheapie 2" aftermarket gauges into. I didn't feel like buying all the senders and looking up all the differnt wires . some of the colors even changed from Idiot light to gauge wiring. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
![]() Join Date: Apr 2001
well, its actuallypretty easy, just tedious... I did the swap on my 74, and only a few wires were different... I had both clusters out and compared the circuit board patterns from one to the other... each elect. gauge needs a hot, ground, and the sending wire.. many times the hot and ground circuits connect between more than one gauge... if there is only one dedicated connection between the dash connector and the gauge, its the sender wire... I had the diagram of how i did it, but recently discovered it had coffee spilled on it and is now pretty much unreadable... but if i can do it you can too.. you will need the gauge approprate sensors for the oil pressure and the temp gauges to work properly... if you have any questions while doing htis let me know.. OH i made the changes by using a jewelers screwdriver to change the position of the wires in the male dash connector...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#5 | |
hey i see by your sig that you dropped a 305/200 in place of the old straight six. drop me line at the same old all4trux@snip.net and let me know how your making out. As long as you are still in Minn. go by the Vikings field and ask them what the heck happened to them this year ?????????? Kick Dante in the A$$ and tell him it's from me--then run of course. Dont worry there is no one on the team this year that could catch you :-) I've been waiting for those losers to win a super bowl for me for more years than most of the guys on this forum have been alive. DAVE
#6 | |
The guage cluster that I bought to replace the dummy set-up is from a 1987 TBI Truck.The way that the speedometer is held on the back of the gauge is different between the two. The one that came out of my Blazer attaches to the plastic housing, while the other cluster has a clip on the back of the gauge itself to hold the cable in??? |
