Old 10-21-2005, 12:42 AM   #1
FnLow69
FnLow69's Avatar
Exclamation 20's??
will a 20X8.5 with a 5.4" backspacing work on my back 69 GMC that has a disc brake/ 2.5 in drop spindle conversion, i wanna lay frame so i well be Zing the frame. will that backspacing work? There centerline Smoothies. also what size tire will fit and be under 27 inches tall? any help is apperciate. thanks
FnLow69 is offline   Reply With Quote
Old 10-21-2005, 08:58 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 20's??
I can't help you on your back space issue since I'm not familiar with the clearence on your 69. I can offer a couple of good tire sizing calculators that will allow you to answer your tire questions-
Tire Calclator
Another one
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-23-2005, 09:04 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: 20's??
They'll work ok up front but not out back. I've got same size wheels w/ 5.25" BS and disc conv. up front as well. They are fine up front but too much BS for the rear. I'm going to have to get 1" spacers out back. They're rubbing the inner fenderwells in the corners. NOT GOOD. For tires you can run 255/35/20.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-23-2005, 10:41 PM   #4
FnLow69
FnLow69's Avatar
Re: 20's??
hey thanks for the answer guys, as for the rubbing issue Iam going to make custom wheeltubs so theres no problem there. how tall is a 255/35/20??thanks for the help
Old 10-31-2005, 07:13 PM   #5
BigSky71
LAIDOUT
BigSky71's Avatar
Re: 20's??
Using the link from N2TRUX:
255/35/20
Section Width: 10.03 in 255 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 8.5 - 10 in
Overall Diameter: 27.02 in 686.30 mm
Sidewall Height: 3.51 in 89.154 mm
Radius: 13.51 in 343.15 mm
Circumference: 84.88 in 2155.9 mm
Revs per Mile: 769.8
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 10-31-2005, 09:39 PM   #6
67Fleet
67Fleet's Avatar
Re: 20's??
The problem is with that much backspacing they will be "over" tucked. Mine at 5-1/4" bs sat inside the fender lip by over 2". it looked retarded.
-Bret
