Old 10-21-2005, 01:06 PM   #1
70GMCer
70GMCer's Avatar
Oil Pan Removal ?
Can the 350 CI oil pan be removed on our trucks, without lifting the engine up or out completely?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-21-2005, 01:39 PM   #2
Joe67
67 is sold
Re: Oil Pan Removal ?
I was told it has to come up a few inches at least
Just unbolt the two mounts, the trans mount and lift a little
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-21-2005, 02:14 PM   #3
GMC70c20
I think you can if it is a 4 wheel drive but other wise you have to un-bolt motor mounts and trans mounts. Just take the bolts out that go through the frame then put a bottle jack under the balancer then put a 2by4 inbetween the mount and frame and take the inspection cover off. Then you should be able to get the pan out.
GMC70c20 is offline   Reply With Quote
Old 10-21-2005, 04:54 PM   #4
70GMCer
70GMCer's Avatar
That's what I was afraid of.....thanks for the info. That's what I'll have to do then........
1997 GMC Sierra Ext
1965 Mustang
Old 10-21-2005, 05:03 PM   #5
cst70rocket
Don't take the trans mount bolts completely out, just back them out 1/2" or so and it will give you enough play to raise the front up plenty. I'd use a cherry picker to lift if available. Bottle jack and 2x4 prone to give ya problems, don't ask me how I know.
Kirk
cst70rocket is offline   Reply With Quote
Old 10-21-2005, 05:07 PM   #6
Russell
Professional Grade
Russell's Avatar
Make sure you secure the engine once you've lifted it. You can very easily loose fingers if a bottle jack fails while you've got your fingers up there.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-21-2005, 09:49 PM   #7
truckdude239
truckdude239's Avatar
jack it up and take an 2x4 and cut an slit in it for the bolt and place it in between the motor mount and frame it will hold engine up
truckdude239 is offline   Reply With Quote
Old 10-21-2005, 10:10 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
be careful of the distributor cap if it is close to the firewall or you might crack it before you realize it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-21-2005, 11:51 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Unbolt the fan shroud too or you will crack it when you jack the engine.
Old 10-22-2005, 05:46 PM   #10
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Kirk
yes your rigth use a cherry picker never jack the engine up from the balancer
the problem would be bearings get wiped out and pressure on the crankshaft isnt good for it too
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
