Old 10-21-2005, 10:51 PM   #1
jcarlar1
You Are Not Forgotten
jcarlar1's Avatar
Tranny line help
I'm wondering if any of you have bought pre-bent trans cooler lines for a 700R4 in a 67-72 and if you have , where, and approximate cost. Any leads would be greatly appreciated, John
If you don't know where you are going, any road will take you there!
jcarlar1 is offline   Reply With Quote
Old 10-21-2005, 11:20 PM   #2
cdowns
cdowns's Avatar
Re: Tranny line help
i just used a set of th350prebent that i got from LMC they worked good //the inlet outlet of the 700r4 20049 are in about the same locations as the original th350
Old 10-22-2005, 02:10 AM   #3
Jakes-66-K10
Jakes-66-K10's Avatar
I got my cooling line from Autozone, it's all flexible so I didn't have to worry about bending. I just routed it inside the frame and used the existing fuel or brake lines to help route the tubing and keep it from getting near moving parts. Been holding up great so far, was cheap, and took just a few minutes to install.
Jakes-66-K10 is offline   Reply With Quote
Old 10-22-2005, 02:54 AM   #4
GMCPaul
We carry the correct pre-bent 700R4 transmission lines for 67-72 trucks, you'll find them in steel or stainless steel here on our site
http://www.gmcpauls.com/engine_&_transmission_lines.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 10-22-2005, 09:01 AM   #5
jcarlar1
jcarlar1's Avatar
Thank you all for your response, GMC Paul you will find that the order has been placed today. By the way thanks for super fast shipments on all my previous orders, you're a good man to do business with! Thanks again, John
