Old 07-07-2002, 10:02 PM   #1
Desert Rat
Desert Rat's Avatar
Whos the 73 up Tach Dash expert?
I have 2 Tach Dashes 1 with a Volt Gauge on with the Amp gauge.I have a 79 Blazer,and it has the volt gauge cluster w/o tach.I want to put in the amp gauge unit becasuse its extremly nice,not the usual junkyard find,but i know i cant stick a amp gauge cluster in a volt gauge truck without some meltdown.Can i swap the amp and volt gauge around and then the circuit board?They both have mechanical oil pressure.Do i have any otions here,the one tach dash that i need in there i dont consider nice enough to put in my Blazer.They both work.the one cluster looks like it just came out of box,other been in a truck sitting for 10 years,some fading etc.Any help appreciated,i know theres someone on here thats a 73 up tach expert!!!
Desert Rat is offline   Reply With Quote
Old 07-10-2002, 12:10 AM   #2
crossy
Oh,you can't buy that new
crossy's Avatar
tach dahes
UHHHHH expert . I,m still learning after 15+ years of 73-87"s and 5 years of these blasted tach dashes ,but here goes. put the VOLT gauge & correct PC in and you'll only be half way there. The mech oil pressure dashes are wired(PC -wise) totally different from elect oil pressure gauge ones . I just helped a guy do this and it took me many hours to figure out the wiring. If you find a tach dash with elect. oil pressure and volt gauge it will plug right in then you wire the tach seperately . I did keep a draft of the wiring info I sent him. sorry no EASY fix on this one. DAVE.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-10-2002, 04:03 PM   #3
Desert Rat
Desert Rat's Avatar
Crap think ill sell them both and buy a nice 79 one.if i remember right one came out of a 78 other i swore 79 only visual front differance is amp/volt gauge.Or go with the white gauge sticker kit i have.
Old 07-10-2002, 04:04 PM   #4
Desert Rat
Desert Rat's Avatar
both of these are mechanical oil pressure
Old 07-10-2002, 05:42 PM   #5
raggedjim
raggedjim's Avatar
Desert Rat, If you decide to sell I may be interested. I have a '77 2wd blazer I wouldn't mind having a tach in.
raggedjim is offline   Reply With Quote
