Old 10-22-2005, 01:24 PM   #1
76bonanza
76bonanza's Avatar
gear selector
My gear shift is one gear off from my tranny(left of park=park park=nuetral n=drive and so on.)
Is there an easy way to adjust this or should I just live with it?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-22-2005, 03:11 PM   #2
Sweet72
Sweet72's Avatar
Re: gear selector
The '72 has an adjustment in the auto trans linkage rod on the steering column. Open the hood and look for the adjustment on the upper end of the rod.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 10-22-2005, 04:36 PM   #3
pjmoreland
pjmoreland's Avatar
Re: gear selector
You'll know you have it adjusted correctly if you can shift between N and D without pulling back on the shifter lever.
pjmoreland is offline   Reply With Quote
Old 10-22-2005, 05:00 PM   #4
76bonanza
76bonanza's Avatar
Re: gear selector
Done works like a charm now thank you to sweet72 and pjmoreland
1968 c10
lowered 3" 4"
Old 10-22-2005, 06:04 PM   #5
Sweet72
Sweet72's Avatar
Re: gear selector
Your welcome, glad you got her straight.
