Is there a special plate I can purchase to hook up my original quadrajet choke to my Edelbrock intake(2101)?I was wanting to hook up my divorce choke but the guy's at my local auto store have no clue.I figured some one here has an answer.Thanks for the help and the new board looks great
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 10-22-2005 at 09:41 PM. |
WTB this ad
Re: Quad. and Edelbrock intake choke
Both of my intakes came with a plate that bolted to the intake for the choke. The choke from the factory intake should bolt/screw right on to this plate. It seems like I had to flip the rod(turn the part that faced the outside of the truck to the inside, not flip top to bottom) to make it fit. Once you get it where it fits I think the rod has to be bent to adjust the choke. I could be wrong about the adjustment procedure. Both of my trucks have the ebelbrock intake and they both run a factory choke. I also do not run the factory cover that goes over the spring part of the choke.
![]() ![]() Join Date: Jan 2005
You need the Edelbrock choke adapter (part number 8901). Edelbrock also sells a choke rod that will fit correctly (part number 9171). You can order these from www.summitracing.com.
If that is the plate I need then I got it,I can't seem to figure how my choke spring hooks to it.Do you ever have one of those days where the simplest things can just kick your A#%.It's my day
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
I looked through my catalog and they didn't have it in there(Summit) ,just went through the on line site and found what I need.Thanks for the Help
I have a divorced choke on my stock intake and q-jet The rod that I have keeps the choke plate in a straight up verticle position. I have always thought the rod was too long not sure. That part # for that rod from summit should help.
WTB this ad
Your stock rod will work. Both of my trucks have the stock rod on them and the choke functions on them both.
