-Chris
![]() Join Date: Sep 2002
ignition switch
Im having trouble removing my ignition switch so i can redo my dash. Ive read somewhere before about the piunhole but I forgot the exact way to do it. Thanks for any help on this.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
Re: ignition switch
Use a paperclip or section of welding rod to push in on the spring in the hole. every switch i've worked on, the spring seems to be in a slightly different position, but its somewhere near the accessory position. you got to push in the spring, and rotate the entire assy to get it out... takes time and patients
#3 | |
Thats the Hillbilly way
Re: ignition switch
Like he said Paper clip ( wire) in hole turn toward Ass. Sometimes a little WD 40 helps .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 10-23-2005 at 11:58 AM. |
"Trucks with Class"
![]() Join Date: Jul 2000
Re: ignition switch
You are working on one of the most hateful items on a chev truck. I just spent way too much time on one yesterday!
When you turn the key to acc, you then have to keep the spring loaded pin pushed in while you wiggle and pull on the key to get the center of the lock to release. Try loosening the bezel to take pressure off, but the lock has to come out before the bezel can come completely off. When I went to put it all back together, the new lock would not work with the new switch from a different company ![]() Put a little lube/antisieze on the bezel threads. They are really fine and cross thread easily. When you put it back together, just push the center lock into the acc position and turn to the right...it locks itself. |
-Chris
Re: ignition switch
Alright, well I have a slight problem. I bought this dash that I am restoring from "Burnsman", it has the ignition switch in the dash and I want it to come out to put in the new one. The problem, I dont have the key to the ignotion. hehe. Now what do I do?
"Trucks with Class"
Re: ignition switch
No key? I usually use a cut off wheel and cut the switch into a couple pieces and just replace all with new parts. Don't cut the harness or tabs/fingers that lock the harness to the switch housing.
