FS 68-72 LW bed & other stuff
Decided to use a later model bed, so I'm selling this one. Someones been working it, -it has small amounts of bondo at the stake holes ?? right side is straight -left side is dented behind where the bondo can be seen. It is not rotted but has heavy pitting in the floor at front. Floor has some dents -tubs have small dents/dings. (I'd intended to Por 15 -coat with Rhino liner type kit the floor) Rear panel has holes cut for bumper braces, -I have another bottom to cut patches out of. $200 --Have a gold LW tail gate thats real decent/no rot $150 --Another LW gate a little dented $40 --left LWB side -has pin holes in wheel arch and some damage/some rust where tub meets inside. $30 --67-68 hood with 4 small dings/dents $25 --67 left fender a little bondo and a pin hole in pocket $25 --pair driver trailing arms from 3/4 $40 --1 in cab tank $25 Email for other pics, Thanks -Steve
Re: FS 68-72 LW bed & other stuff
Do you have pics of the tailgate? I may be interested if it has the woodgrain trim.
The gold/nice gate is from a 68,- I should have described it better. It didn't have the woodgrain. The other gate did have it/Bad shape. Trim's all off of both. Will get pics shortly of both gates if you still want to look.
Do you a set of spark plug heat shields for the rams horn manifolds. I need the wire loomd for the rear of the engine and under the manifolds too. Thanks.
No I don't, sorry.
bump
![]() Join Date: Jul 2004
Put me first in line for the good tailgate -Tom
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Ok it's yours then. Sending a PM -Steve
Bump-_-_-_ I have pics of everything -can send. Send your email in a PM -Steve
bump
PM and Email sent -
Tom
