Old 10-23-2005, 04:57 PM   #1
masterbeavis
Having issues
masterbeavis's Avatar
What was the 11,000# axle for a C30?
I was snooping around the parts computer at autozone. I looked up a few things for a one ton rear, there was 2 listings, the normal, and one for a 11,000# rear axle. Is this the difference between the HO72 and the HO110? What was the ratings of the 3 flavors of that axle? (the 52, 72, 110)
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 10-23-2005, 08:34 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: What was the 11,000# axle for a C30?
never heard of the 110 one before
tnblazerk5 is offline   Reply With Quote
Old 10-23-2005, 08:45 PM   #3
Russell
Professional Grade
Russell's Avatar
The newer 73+ duallies were rated for 11 500 lbs, but I've never heard of a single rear wheel axle with that heavy of a weight capacity...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-23-2005, 09:35 PM   #4
masterbeavis
Having issues
neither have I, only as high as 7500# IIRC, maybe it was a dualie they were refering too. The computer did not specify. THere is something bigger than the 72, but my search skills are not good enough to do a search for it
Old 10-23-2005, 10:12 PM   #5
masterbeavis
Having issues
Found what I was looking for on another board.
Not always true...all 3/4 ton 4x4 Chevy's and GMC's have rear leafs, and either the dana 60 or the H052.
All Longhorns had leaf springs, 3/4 tonners used the H052 (unless a big block was ordered, then they got the dana 60) and 1 tons used the H072.
All Chevy 2wd 1/2 and 3/4 trucks had coils stock. GMCs had leafs stock. But, leafs were optional for Chevy and coils were optional for GMC. All 1 tons had leaves.
Above statements for 67-72 trucks only.
The H052 and 72 are the same axle with minor differences. Like the 3/4ton and 1 ton 14 bolt. The 1 ton axle will have bigger drums and backing plates. There is also the load bolt, but I am unsure what dictated if the axle got it or not.
Some people have said that some of the bearings are different in the H072 axle. As soon as I get my H072 center section (soon hopefully ), I will compare the two. Right now I just have a H052 from a '66 Chevy C20.
EDIT: The H110 was an optional axle in C/30 trucks and some step vans. It had the standard 8x6.5 lug pattern, and a massive 12.25" ring gear. I am unsure of axle size/spline count. A quick way to tell it apart from an H052/72 is that the 110 has a welded on diff cover from the factory, & the smaller ones have a bolt on diff cover.
Old 10-23-2005, 10:12 PM   #6
FormerMember
Check out a C50 and you'll see a large top loading Eaton. Heck, check out the 50's Army Deuces.
That's the 11,500 axle. They have bigger ones...
FormerMember is offline   Reply With Quote
Old 10-23-2005, 10:39 PM   #7
muddyole 69
Beavis I got a chuckle on the quote Reservoir Dogs very cool movie later Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 10-23-2005, 10:41 PM   #8
masterbeavis
Having issues
keywords for search to find this thread
H052
HO52
H072
HO72
H110
H0110
only H110 works for search seems like
[edit] changed the "o" to a zero instead of a letter, now maybe this thread will show up in search
Old 10-23-2005, 10:46 PM   #9
masterbeavis
Having issues
THe pink user names made me think of that. Too bad I had to hack it up to make it fit less than 250 characters(sp)
Old 10-23-2005, 10:46 PM   #10
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The HO52 and HO72 are the same rears with the 8 lug x 6.5" bolt pattern, except for the pinion load bolt(HO72's and some 52's) and the brake size(HO72 brakes are bigger). The H110 had 10 lugs with either 18", 19.5", or 20" dually rims. It did have a big ring gear and had a welded diff. cover, and the pinion bearings are the ball type, not sleeve bearings like the 52 and 72 have. Here's some pics I saved that a member took of the 110, hope they don't mind me using 'em:
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 10-23-2005, 10:56 PM   #11
FormerMember
I am sure glad I am not pink...
Old 10-23-2005, 11:24 PM   #12
masterbeavis
Having issues
looks like josh is getting alot of taco bell money now.
Old 10-24-2005, 08:08 PM   #13
tnblazerk5
User #12137
tnblazerk5's Avatar
so thats whats in my 1 ton 69 frame is a h110 ? heres a pick of it
i am going to junk the h110rear for a newer 14 bolt duelly when i find one
Old 10-24-2005, 08:46 PM   #14
masterbeavis
Having issues
I made a realization today about something. I think the model number coresponds with the weight capacity of the axle. What gave it away was the H110=11,000# axle. The H052 is 5,200#, and the H072 is the 7,200# axle. That would be my guess on that question.
is it 10 lug?
Old 10-24-2005, 08:49 PM   #15
tnblazerk5
User #12137
tnblazerk5's Avatar
yup its 10 lug if i could find a 10 lug 4x4 front end i would keep it but i dont think they made a 10 lug 4x4 front end or if i could find wheels to fit the rear that werent split rims i might keep it 2 wheel drive
Old 10-24-2005, 09:18 PM   #16
FormerMember
is it 10 lug?
Dawn breaks over Marblehead?
Same with the Dana axles...
30= 3K rating
44=4.4K rating
Old 10-24-2005, 10:25 PM   #17
masterbeavis
Having issues
TNBlazer:
10 lug front ends are available, you just have to look harder, and in different spots. Try F450 and up pooper duty trucks (10 lug) and prolly GM has em too
And John, if the 44=4.4K is true how come the 60F wasnt rated at 6K for the front?
Old 10-25-2005, 10:25 AM   #18
tnblazerk5
User #12137
tnblazerk5's Avatar
TNBlazer:
never seen a 10 lug 4x4 front end before what years f#$ds f450 had them ?
and is there rims that will fit a 10 lug that arent split rims ?
Old 10-25-2005, 09:02 PM   #19
masterbeavis
Having issues
Keyword was pooper duty. 450 and up "should" be 10 lug. Pumpkin will be on wrong side, but a transfer case can fix that. You are on your own for figuring dodge or GM products, I dont know anything about them. I am a furd guy lured to the darkside over first gen blazers.
Old 10-25-2005, 09:15 PM   #20
tnblazerk5
User #12137
tnblazerk5's Avatar
the tranfer isnt a big deal all i would need would be a f@#d 205 case to make it a left hand output but finding a 450 and up may be a problem lol
now about those rims did they make any other rim to fit them besides the split rims ?
Old 10-25-2005, 09:47 PM   #21
the 19.5" rims are tubeless and you can also get tubeless 22.5's but those might not fit. i've been working on a 1960's step van and it has 8R19.5 tires but it's 8 lug. what size are the wheels on your 69?
RJD
Old 10-25-2005, 09:50 PM   #22
tnblazerk5
User #12137
tnblazerk5's Avatar
i am not sure i will have to look seams to me they are 19.5s but like i said i will have to look i know there big and skinny
Old 10-25-2005, 11:28 PM   #23
masterbeavis
Having issues
I would imagine that the 10 Lug donor would have the rims you need. I dunno if the bolt patterin is tho. Measure yours, we can go from there.
info and pic leeched from kleenwheelsincolor.com
determine the bolt circle, measure from the center of one stud hole directly across the center of the wheel, to the center of the opposite stud hole (see diagrams). Measurement should equal the bolt circle diameter.
FOR 5 LUG BOLTS (I am putting this in for the search engine, not related to the thread)
To determine the 5 lug bolt circle, measure from the center of one stud hole, skipping the adjacent hole, to the center of the furthest stud hole (see diagram). The measurement will be slightly smaller than the actual bolt circle diameter, but may be converted to the bolt circle diameter using the table located below.
Old 10-26-2005, 12:38 AM   #24
masterbeavis
Having issues
there is hope
Old 10-26-2005, 07:08 AM   #25
Rod
The H072 could come with an auxillary spring kit that brought the GVW up to 11000 lbs on the rear...more common on longer 157 wheel base trucks..but was available on the 133 inch dullies also..my 72 1 ton has it.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
