Old 10-23-2005, 07:52 PM   #1
chevybill
chevybill's Avatar
Exclamation this just in from the "i feel stupid" files
Hey guys, I just spent the afternoon trying to use 6 cylinder engine towers to mount a 350 vortec motor in my 70 c 10 chassis. Once, I stopped and thought about what I was trying to do I just shook my head in shame.
I need suggestions for v 8 mounting engine towers, I have the old stye 3 bolt rubber pads already on the 350 (new old style mounts not the original dry rotted).
Do any of the vendors repop v 8 towers? Towers are the steel part that attaches to the rubber engine mounts and to the rails of the truck.
Any suggestions and part numbers appreciated.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 10-23-2005, 07:56 PM   #2
billsbowtie
billsbowtie's Avatar
Re: this just in from the "i feel stupid" files
i have a pair of good used ones $35.00 shipped to you. bill
billsbowtie is offline   Reply With Quote
Old 10-23-2005, 08:08 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
So exactly how many hours did you spend trying this
J/K with ya, I would have lost it trying to figure it out
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-23-2005, 08:10 PM   #4
Slammed66
Needs a Big Block
Slammed66's Avatar
you should have still been able to bolt in the motor using the 6 cyl stand the motor will be Lower I think. unless they are from a 292.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 10-23-2005, 08:18 PM   #5
chevybill
chevybill's Avatar
billsbowtie, pm sent
2 hours of lost time
if they can be made work please let me know
Old 10-23-2005, 08:32 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
i got a 327 bolted to the 6 banger stands all it did was move the motor back
wait i cant remember what mounts are on the motor i will look in the mornin
tnblazerk5 is offline   Reply With Quote
Old 10-23-2005, 09:06 PM   #7
pjmoreland
pjmoreland's Avatar
What kind of transmission do you have?
pjmoreland is online now   Reply With Quote
Old 10-23-2005, 09:11 PM   #8
chevybill
chevybill's Avatar
I have a late model 5 speed that was behind a 4.3 in a s-10.
i think that my shifter is going to be real close to my seat or I may possibly have to have buckets due to the shifer being on the back end of the tranny.
but what does that have to do with this thread?
Old 10-23-2005, 09:20 PM   #9
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I used the 6 banger stands on mine also, 98 vortec and used 68 327 mounts on motor and a turbo 400 trans mount on the 4l60
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 10-23-2005, 10:15 PM   #10
shifty
Questionable
shifty's Avatar
I can vouch for Bill. Top notch seller.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-23-2005, 10:42 PM   #11
pjmoreland
pjmoreland's Avatar
The location of your engine stands is going to affect where your transmission crossmember needs to be mounted. The inline 6 stands mount farther back than the V8 stands. Considering that your shifter is so far back, it sounds like you would be better off moving the engine forward on V8 stands.
Old 10-23-2005, 10:53 PM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I thought the stands were the same,just the location was different.Am I wrong on this?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-23-2005, 11:00 PM   #13
pjmoreland
pjmoreland's Avatar
The stands are different. The V8 stands have a curve to them when viewed from above, but the I6 stands are straight.
Old 10-23-2005, 11:06 PM   #14
Yeah,they`re different.The V6 will sit lower on the I6 towers.It`s best to mount the V8 forward in it`s intended position.The fan and shroud will be correct and you`ll have more room for distributor,especially HEI.
Old 10-24-2005, 08:20 AM   #15
chevybill
chevybill's Avatar
thanks for all the replies,
i have been trying to mount in the v 8 position so i could get the shifter as far forward as possible.
i may have to have a "c" shaped shifter formed to have a middle part of a seat or i may have to have 2 buckets only
looking like the shifter will be about nine inches back from the front cab mount.
Old 10-24-2005, 10:20 AM   #16
64fleetside
Seems like there is 3 1/2-3/4" diff in the two positions if I recall, the six stands will not work in the front holes. Brian
64fleetside is offline   Reply With Quote
