Old 10-24-2005, 02:33 AM   #1
BowTieMan
BowTieMan's Avatar
Steering Colum
When I put in my floor shifter what can I do about the colum were the old shifter was. Can I just get that cover off a truck with a manual and swap them right over?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 10-24-2005, 03:05 AM   #2
Americanrider
Re: Steering Colum
Changing out the column collar can be a big pain, best to get a Manual column and do a straight swap. Auto columns are selling good on fleabay if they are in nice shape, or maybe you can find a member to swap you straight accross.
Americanrider is offline   Reply With Quote
Old 10-24-2005, 10:46 AM   #3
dennislbrooks
dennislbrooks's Avatar
Re: Steering Colum
You can do body work on the manual collar as I did and you cannot tell the difference. Will send you a pic if needed. Of course if you have a floor shift collar--- a lot easier.
dennislbrooks is offline   Reply With Quote
Old 10-24-2005, 11:02 AM   #4
truckdude239
truckdude239's Avatar
Re: Steering Colum
mine was converted over to the floor and i'd like to get ird of the ungly collar on my cloumn lol
truckdude239 is offline   Reply With Quote
Old 10-24-2005, 06:22 PM   #5
dennislbrooks
Re: Steering Column
pic of a converted 3 on tree. Remove, cut or gring pot metal shifter protrusion. Clean, Use a lab metal or hardner to fill nost of the hole, finish off with good old bondo.
Old 10-24-2005, 10:27 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Steering Colum
Removing the colar off a 4 speed truck is simple, as is installing it onto your column.
