Old 10-24-2005, 10:45 AM   #1
mplex2000
mplex2000's Avatar
Roller cam conversion question
Posted this over in Engine and Drivetrain, but I never get any answers there so here it is again:
I'm wanting to retrofit my old 350 block with a roller cam. None of the grinds out there will work real well for me, though.
I was looking at a "stock" ZZ4 cam which is a nice mild looking grind. Can this cam be installed in an older non roller block using the typical aftermarket roller retrofit lifters?
Thanks,
Chris
mplex2000 is offline   Reply With Quote
Old 10-24-2005, 12:12 PM   #2
wolfthing2000
Re: Roller cam conversion question
I am doing exactly what you propose with a 383 build. You need the roller cam, of course, roller lifters with the vertical bars, new push rods and guide plates on heads. Roller rocker/roller tip to complete the set-up. Don't forget stronger springs etc.
wolfthing2000 is offline   Reply With Quote
Old 10-24-2005, 01:17 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes.
There is a fellow here in town that did exactly that. He bought a ZZ4 cam out of a crate engine and used aftermarket roller conversion roller lifters in an old, non roller cam, block. It works fine.
Old 10-24-2005, 02:04 PM   #4
mplex2000
mplex2000's Avatar
Sweet, thanks guys.
Old 10-24-2005, 02:05 PM   #5
mplex2000
mplex2000's Avatar
While I'm thinking about it, does the ZZ4 cam require a bronze dizzy gear?
Old 10-24-2005, 08:00 PM   #6
FormerMember
It's advised.
You also want to use the cam button I included with a stronger timing cover plate.
FormerMember is offline   Reply With Quote
Old 10-25-2005, 02:20 AM   #7
4x4Poet
In case you want to go on the cam dist gear:
http://store.summitracing.com/defaul...3&autoview=sku
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-25-2005, 04:09 AM   #8
jimfulco
Or if you want the cheaper GM alternative: http://www.sdpc2000.com/catalog/924/...butor-Gear.htm
jimfulco is offline   Reply With Quote
Old 10-25-2005, 06:50 AM   #9
FormerMember
I included a .05 bronze distributor gear, I thought?
Old 10-25-2005, 08:35 AM   #10
mplex2000
mplex2000's Avatar
Yeah, I already have the gear and the button. I'm guessing your pushrods should work as well. As grendel knows, I have a set of lifters ... but I bought mechanicals on accident, just a stupid mistake. Now I still need lifters and the cam. I've already got the manifold off since I was replacing the Victor that came on the truck.
Going to run a Holley dual plane until I go EFI. I'd like to swap to some nice heads, but I need to get the truck running and inspectible so I can take care of some other stuff. Hopefully I can pull off the cam swap while I've got it apart. I've got new suspension, brakes, wheels, etc. Lots of upgrades at once
