Collector of Projects
ECE Late Model 4.8 5.3 6.0 Engine Mount Kit
Has anyone seen these? Used them? I am contemplating a 6.0L/4L80e swap for my 71 SWB with a Painless Harness and maybe these mounts. I sent ECE an email. They say "Slight frame modification may be required, depending on application"
http://www.earlyclassic.com/ProductI...II%20MOUNT.JPG 63-72 Gen III Motor Mount Conversion Kit (Kit) Looking to install a late model Generation III engine in your 1963-1972 C Series Truck? Early Classic once again leads the way with our new Generation III Mount Conversion Kit that allows you to bolt in a 1999 or newer 4.8,5.3,5.7, or 6.0 GM engine directly into your engine bay. |
Re: ECE Late Model 4.8 5.3 6.0 Engine Mount Kit
rich probably the only mod needed would be slight clearance for the exhaust manifolds. this should be minimal.
I made the same type mounts but I built up off teh cross member instead of the plate mounting from the top to the bottom flange on the frame rails this gave me more room for the vette manifolds I used. so far it hasnt jumped out of the truck... Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Questionable
Look at my gallery
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Questionable
Having issues
Heh, I thought I read the title as FREE late model 4.8 5.3...... Darn sun comin thru the window.. I was like, I need to read this before it gets deleted!!!
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
Shifty,
How was the fit? Looks tight. What exact motor did you use(from what)? I read a few of your posts on the LS1tech site. You said something about a 99+ truck oil pan. I am guessing you kept the stock accessories and mounting brackets by the looks of the pics... Do you think the engine sits high in the frame? |
![]() Join Date: Apr 2005
If you are using the truck 4.8/5.3.6.0, I think you will only have to notch on the passenger side for the a/c unit. I've bought my engine (5.3/4L60e) and the ECE kit for my 1969 suburban, but haven't started yet. I still need to gather some more parts, gas tank (I'm going to have FuelCell guy build me one), electric fans, wiring harnes (probably S&P), misc......
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#8 | |
Questionable
I want to get everything done this weekend but It's looking like I'll be too tied up ... AGAIN ![]() It's still not in. They look great and the fit of the mounts seems to put the engine right in the perfect place so just the right angle is on it and the weight is distributed how/where it should be in reference to the wheels. I've only done a test fit so far - you gotta test fit them, drill new holes in the cross member (it uses the exiisting frame rail holes) and mount them, then drop the engine in. OVerall, I am VERY happy with the craftsmanship and couldn't ask for a better part. As for the fit --- The A/C compressor is too wide. I refuse to notch the frame right now, so I'm just going to get it all going without A/C for now and cross that bridge later when I get a welder and it's not cold as hell outside. If anyone else has questions, keep em coming. I'll be happy to answer anything you want. If you have questions about any of the pictures also, please, feel free to ask.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 10-25-2005 at 10:42 PM. |
hey, thanks for the info on the gen III stuff here. Doesn't your engine have a truck oil pan on it? Is it the Vette GTO CTS-V engine? The accessories would be completley different on that to my recolection. I've been selling them for 5 years i really should know but i don't. I'm thinking about a 6.0 in front of 4L80 mated to a np205 in a 72 k20, i have to sell my c10 first though. Cutting the frame is a big concern for me, have you found manifolds that fit nice? Also, i know GM pp makes a serpentine kit for sbc, i wonder if this would mount up the newer accessories and keep from having to cut the frame? Can you use a new style compressor with vintage air or stock 72 air? Fuel injection is AWSOME!
#10 | ||||
Questionable
Either way, I got the new pan, new oil pick up tube, dip stick and dip stick tube should arrive tomorrow and I get to promptly leave town and can't install it till next week ... so the project is stalled yet another week. At this point, I'm hoping to get done by Christmas. :\ Quote:
![]() ![]() Quote:
You can use the PCM (computer) from an LS1 with the 6.0 (LQ9 or whatever?) engine that's in the Escalade. Lots of parts to interchange there from what I understand reading other websites. Quote:
http://67-72chevytrucks.com/vboard/s...75#post1310375 Here is a link to a thread I'm working on over at LS1tech.com with more links to useful info: http://ls1tech.com/forums/showthread.php?t=370781
Thanks for all the info. i have a lot of info to sift thru. I am thinking LQ9 6.0 HO from the Escalade. I looked at firstgen's thread and it sounded like he had to hack up the frame to make the compressor fit. I Hate that, but if Its a must it's a must. He's got that thing running 450 HP! I want one bad. Again, thanks for the help.
1969 K20 not running, complete but rusty with wrecker boom and push bumper 1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina" 1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed "Choose a job you love, and you will never have to work a day in your life." Confucius |
Questionable
I got everything in. I gotta say, this engine mount kit rocks. I need to have a high hump for my tranny now though, so I'm waiting on that. My entire project is stalled until I can buy it and have it shipped here.
#13 |
![]() Join Date: Mar 2004
it's strange how familure these brackets look. i posted this faq on how to do this last year and it will cost you way less than $100 installed.
How to adapt 73-87 engine mounts to a 67-72 frame |
#14 |
Questionable
Excellent post, roj. You think they mighta stole your design?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-18-2005 at 01:33 AM. |
