Whats your Maintenance Schedule?
Just wondering what you guys think on how often to do maintenance to our trucks to keep them running smooth. (oil, plugs, wires, cap/rotor, etc) ?? I need to put together a plan to keep the old girl happy
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Old Skool Club
![]() Join Date: Jun 2001
Re: Whats your Maintenance Schedule?
Keeping the "old girl" happy means not spending any money on my truck....
As for maintenance, oil/filter/lube is done annually. I only put about a thousand miles a year on it, for the time being. Yeah, it sucks, but that's what I do. As for the other items....as needed. With an HEI, the plugs and wires are holding up just fine. Probably didn't tell you what you wanted to know, but it's what I do.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Gone Fishing
I just finally put 1000 miles on mine in the last 4 yrs. I normally change oil every year do to the low milage and the tune-up hasn't been done in probably 3 yrs as she still runs great. When I used to daily drive it. i would change my oil every 3000 miles and due a tune-up every 2 yrs need it or not.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Cantankerous Geezer
There are a lot of variables on this. Big thing is what kind of driving you do, next is how the truck responds.
Recommended was oil & lube 3,000 miles or 3 months. Tuneup every 12-15,000 miles. Check air pressure monthly. Check oil at every fill-up. With today's oils, the change can be extended to 5,000 miles if you do a lot of highway driving. However, if the oils is black or cream colored, you're not changing it often enough.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
A.K.A- Crummy
Every 3000 miles or once a year(which ever comes first) Coolant every other year(garaged) Top off other fluids(add or change as needed) 29,000 miles in 15 years. 4 carbs(experiment), 1 radiator, 1 heater core, 1 water pump, 1 clutch, 1 set plugs and wires, 1 set of points, 1 generator, 1 relay, 2 batteries, 2 sets of valve cover gaskets, 1 thermostat, more, maintenance never ends!!
2003 Silverado Z71 Are fishermen all liars? |
Designated A-hole!
Unfortunately I just fix it as it breaks.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Black 72 Chevy
Replace the oil every 3000 miles or every 6 months. All other parts I replace as needed bases.
Where's my beer?
I'm just coming up on 1 year since I got my truck and I plan to change the oil soon. I've put about 1300 miles on it in the last year. I'll pull the plugs and check them while Im under the hood, probably replace the fuel filter. Since how I use the truck isn't going to change, I plan to stick with this routine.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Its Magically Delicious
oil - every 2,000 to 3,000 miles
anti-freeze - yearly spark plugs - whenever they look bad or i feel like a change cap/coil/rotor - when needed Although its good to have extra parts with you ... might safe a tow bill and alot of inconvenience
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
![]() Join Date: Sep 2005
ummm when i feel like it? does that count?
4 eyed fever
Mines a DD, but only put about 1k miles a month, so oil every 3k, antifreeze once a year, fuel filter (inline) once a year, leaks power steering so a little every month, all other maintenance as needed. With the cost of tires these days, it's a good idea to check air fairly often. Unless the PO has meticulous records, it's good to change the diff and tranny and transfer case fluid when you get the truck, cause who knows when it was done last?
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! |
All I do is add oil when my hurting 250 leaks/burns it out. Changing it is a thing of the past. Good thing this truck will have a new V8 next spring after the snow melts.
"You can take the man out of PA, but you can't take PA out of the man" |
#13 |
This thread reminded me that I've been wanting to search online for car maintenance schedules. Found a couple:
Standard printable schedule: http://www.samarins.com/maintenance/simple.html (See "print maint remainder" [sic]) First time seeing this free online maintenance schedule service. Looks very interesting. Register like this site, log your maintenance done, and get email reminders for when its time to lube, change the oil, tune-up, whatever: What could be easier? Can't loose the schedule sheet, either. I gotta explore this one for my *fleet*: ![]() ecarlog.com/
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 10-25-2005 at 01:32 AM. |
#14 |
Shift it when it floats fix it when it breaks
hav'n fun be'n me ![]() |
#15 |
Cool, thanks guys. Just what I was looking for. I was thinking it was time for a tuneup and you confirmed it.
#16 | |
Thats the Hillbilly way
![]() Quote:
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 10-25-2005 at 11:28 AM. |
#17 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The Haynes 67 to 87 Chevy and GMC truck manual has one in chapter one that lists all the things and intervals we should do to our trucks. For the record everybody who owns one of these trucks should get that manual. The information in it is invaluable.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
